  • 600-650 rwhp on 93 octane?
    - - 5.3/4L80e/T7875 - -
    - Huron Speed Turbo Kit -
    1998 Formula
    • Originally posted by Formula Z View Post
      60# will suit you just fine!
        Quick question, i still have my stock ls1 cam. Would you use that, the 5.3 cam, or get new? I know the z06 cam was mentioned and its priced well, but just thinking. Thanks
        http://ls1tech.com/forums/forced-ind...urbo-cams.html
        • Funny you mention that... Tick is who I am direct with!
          • Speed inc has some badass turbo cams too.
            http://www.speedinc.com/catagory.cfm...in%20/%20Heads
            2000 Formula
            fixed slow junk
            • Originally posted by Nocooler View Post
              http://www.speedinc.com/catagory.cfm...etrain / Heads
              Not bad, definitely proven performers, but they have had those around for quite a while. Now there have been some good improvements in lobes!
              • Originally posted by Superman09 View Post
                I will keep that in mind b/c this is probably my next cam
                • Originally posted by 1999Black_Z28 View Post
                  Yea, definitely let me know! I have it worked out with them that I can have cam's spec'd and get their shelf grinds!
                  • Nice!
                    1998 Formula
                    • Martin @ Tick is the man.
                        For sure, definitely a cool cat and a great guy to work with!
                        Any needing a custom ground cam for their application let me know!
                        • Nice!
                          Ill be getting with you for mine sometime this winter
                          1998 Formula
                          • How are these look to be pretty good might invest in one of these better the end of the year. I was just reading up over the weekend on good cams and fi. Glad this was posted!
                            05 cts
                            01 silverado 2500
                            96 s10 blazerrr
                            84 k5 blazer
                            • Originally posted by t_ank View Post
                              Just an FYI for you, I am direct with Tick, so if you want any of their grinds or want something spec'd custom for your set-up, let me know and I can get it done for you!
                              Jon
                              • Nice to see you coming over to the dark side Mike! There are a lot of guys running the ls9 cam. If your on a budget it will work great. If your not spend away man. The Huron speed looks really nice, I almost pulled the trigger on one last week. But I just can't have 2 cars under the knife at the moment. It is relly tempting though, that is a great priced kit!
