My expensive used kooks required no welding....banging....or cursing to Install around my aftermarket k aftermarket oil pan.....and aftermarket motor mounts
Exhaust Identification Help
Now that the motor mounts have settled in a bit, the place where I modified the y pipe is like an inch or better away from the subframe now. I need to get used to the vibration transmission from these mounts. The mis was a plug wire that didnt seat in the cap all the way, much better now.
EDIT: no its not, its a bit better but still missing enough to shake the car under power. I needed to drive it a bit to feel the difference between what it was and still is.Last edited by zeeman; December 9th, 2013, 06:38 PM.
