Yeah, I think some sand got all up it there, lol. Eric L
o2 problem (EFI Connection conversion)
if you wanna be technical, that 5.3 block is actually a 325Originally posted by nascarnate326 View Post
lol
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Have 1 harness done and it ohmed out at .2.
Now for the 2nd one if my kids don't destroy my house 1st
Hey bud, I'm holding off on your request. I think things have calmed down!?!??!West Michigan Pontiac Club
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
K, I still had my original Passenger o2 harness that I made and ran on the dyno so I ohmed it out and this is what I got:
12v Power wire Pink: .2 ohm
Hi Res Purple: .3 ohm
Low res Tan: .5 ohm
Ground Black: .5 ohm
I believe we have the problem Houston!
isnt that exactly joel told you?Originally posted by Phantom383 View PostK, I still had my original Passenger o2 harness that I made and ran on the dyno so I ohmed it out and this is what I got:
Low res Tan: .5 ohm
I told him to, lol. It just took a little while to pound it into his head, lol. Eric L
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Once you found out what I did you told me that it was a bad deal.Originally posted by prorac1 View PostI told him to, lol. It just took a little while to pound it into his head, lol. Eric L
Joel was worried that I had a crossed wire or over lashed valves but I think he might have mentioned that also.
I just got that off the car today.
So, are they installed yet? Plug em in and lets see the results. Eric L
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
The dyno #'s are most likely from weak valve springs and that will not be done till later.Originally posted by ThreeHonks View Postyeah did it fix it? still doesnt explain the low dyno number though :/
o2 harness will go back in I hope tomorrow.
I have to go and start building a swing set now
what evidence is there that the springs are weak?
Even if the springs are weak, and i see no reason to believe they are, he has his valve lash set to 3/4 turn past zero. To my knowledge that is within spec but on my car that was NOT an optimal adjustment. As i recall it was starting to pressurize the valve stem if I went beyond 3/4 turn at all. Even if springs are a suspicion try loosening up the valve lash first, it cant hurt. Some people run as little as 1/8 turn with no problems.
I believe mine are set to 1/3 turn past zero lash.Last edited by JoeliusZ28; April 29th, 2010, 07:05 PM.-Joel
