I was going to say sounds like a PCM issue especially with little to no data on a scanner, so I would be willing to bet that the ground strap you were talking about is the culprit. Any time we were not receiving data on a scanner at our shop, we would get a new PCM and go from there as this was almost always what was wrong.
WTF is this???? Might be out for the year..
I need to check that ground into the harness.. I know it is connected to the head cause I can feel it..Originally posted by jetice91 View PostI was going to say sounds like a PCM issue especially with little to no data on a scanner, so I would be willing to bet that the ground strap you were talking about is the culprit. Any time we were not receiving data on a scanner at our shop, we would get a new PCM and go from there as this was almost always what was wrong.sigpic
Did you read any oil pressure on the scanner? Just got off the phone with my dad, and he says that along with a bad ground, it could also be the oil pressure switch, which is on the back of the block, which would kill the fuel pump because of no oil pressure. just a thought
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
didnt see oil press data either but his sending unit is just a one wire.. those type will still run with the conector not pluged in. as far as data period alot of the data either wouldnt display or not change.. like maf would read 0 then one time read 1900 grams so something is not right. i would do exactly as he is planning to remove the intake and recheck for unpluged harnesses or other broken wires, its not hard to remove the intake and be sure with out a doubt everything is in order behind it.sigpic
Yea the oil pressure sender on our cars is only for the gauge in the dash, PCM doesnt use the data.
I really wish you were closer lary. Id love to take a look and see whats up. I live to fix stupid shit like this. Just have to 1 at a time systematically eliminate things.1999 Camaro - 6 liters of fury.....
as I mentioned make sure the ground on the head is there, all years are a little different but my 98 has 3 wires that connect there. I unknowingly pulled one off a while ago and it gave me a headache too.Doing less with more
Well I found it, MAP sensor ground broke off... Deep down I knew if I pulled the intake I would find the problem... Should be running in a few days, too damn cold out in that garage..
IMG_4722.JPGsigpic
Shit, I am frozen from 30 minutes in the garage pulling the intake.. Just happy I found the problem.. It was the last thing I looked at after pulling the intake.. Was pissed cause I didn't see any issues with anything, then started checking shit I thought was good and found the broken wire...Originally posted by 1bad83ta View PostAlways a problem with the ground. Good job Larry! Now get back on that horse and kick some ass!sigpic
