WTF is this???? Might be out for the year..
    vinnie larry will most likely be here too, he plans anyways. i cant believe you cant find another pcm anywhere. i doubt its the problem though. how can it just go bad over the winter for no reason. wait for that scanner and see what you come up with. keep the battery up front for now until its running correctly. you messed something up while messing with the intake or forgot something. im sorry you are having these problems. id be pissed too i know
      Hoping to have the scanner in the next few days... Just need to take a breather...
        probably not a bad idea
          That clicking noise has been common on my car for the last few months too.
          Buy a PCM from PCMforless.com or MadTuner.com
          Hope you get your issues sorted out. I do know that repeated clicking of the BCM can kill it. Ive got a backup BCM now
            new untuned pcm probably wont help much but SMC in auburn hills has them
              Any ideas... The car does the exact same thing every time I start it... Exactly...
              I'll check that stuff you asked about in the other thread when I get the scanner..
                That is the most ridiculous problem i have ever seen/heard. Hope you get it figured out!
                  Thanks Joel... I'll get it figured out, eventually....
                    1. it needs tuned. the issue with it flooding while in speed density shows that.
                    2. raising the max delta airflow p1010 table by 20% or so may stop that code from setting. BUTTT.
                    3 there has to be a ground or map sensor issue.
                    what does the Map read KOEO??? KOER??
                      Wish you were closer larry, otherwise Id pay you a visit with the laptop.
                      Its got to be something unplugged or not connected corretly.
                        I have no idea what KOEO is or KOER.. I am guessing I can find this out with a scanner? It has to be a ground issue, I replaced the MAP today just for the **** of it.. New MAP, exact same problem...
                        That's why I am walking away from it for a bit....
                          key on engine off
                          key on engine running
                            grounds on the back of the head still connected?
                              Good plan, thats what I ended up doing on several occasions with mine this year, came back after a day or so and was able to tackle the problems with a fresh mind and a new approach.
                                you will get it figured out. just keep checking for grounds, shorts, anything like that. maybe you can get tj to bring his lap top over and see what it says? he can see if your tune is off or whatever too
