well if your battery is in the back and it says 5 volts or whatver in the front. and then u move it to the front and u have 12 volts.. obviously something is missed up with the wire between the front and the back.. i would start there first.
WTF is this???? Might be out for the year..
Really? I never would of guessed that(insert sarcasm)....Originally posted by kammi10 View Postwell if your battery is in the back and it says 5 volts or whatver in the front. and then u move it to the front and u have 12 volts.. obviously something is missed up with the wire between the front and the back.. i would start there first.
I have the battery back in the stock location and nothing has changed.. It starts, runs 10 seconds and shuts off, MAF P0101... Not going to worry about the ground issue for the relocation at the moment.. Just going to leave battery up front until I get everything sorted out..
i know you dont want to borrow one but if you decide you want to try it out i have an extra stock pcm you could use.
2000 Z28 - Cammed/Stalled/Intake - Collision With a Tree Mod - Totaled
2005 Grand Prix GXP - Sold
2000 SS - Sold
2011 Ford Taurus limited - Time for a practical car for a bit
Thanks for the offer Dewey.. Does this look odd to anyone else? I pulled my nitrous plate off because I noticed I could seal the TB gasket pretty good behind it(pass side)... I, now, just have the TB bolted to the intake and I can still see the gasket on the passenger side... It is very noticeable.. Is it possible for an intake to warp?
IMG_4716.JPGIMG_4719.JPGAttached Filessigpic
exactly. I think you have been staring at this too long Larry. Sounds more like a electrical issue, or some wires crossed or not plug in or something along those lines. I am assuming you went over everything that you have recently unplugged and plugged back in, correct?Originally posted by c0ncEpT View PostIf it had a small leak you would notice a high idle. In no way would I say thats related to your problem.sigpic
Multiple times... Going to wait on getting that scanner and see what it says... I just can't think of anything... I mean, I do remember when I pulled the intake I unplugged something and said to myself, "must remember to plug this back in"... I can not find anything disconnected anywhere, unless it is behind the intake where I can't see.. But, again, not going to pull it till I see what that scanner says..Originally posted by Darren View Postexactly. I think you have been staring at this too long Larry. Sounds more like a electrical issue, or some wires crossed or not plug in or something along those lines. I am assuming you went over everything that you have recently unplugged and plugged back in, correct?sigpic
Good call, I would just put it in the back of your mind until you get the scanner and can see what that says. Just walk away let it cool down and then go at it with a fresh mind. You'll figure it out, and I am sure the scanner will help.Originally posted by OIF1VET View PostMultiple times... Going to wait on getting that scanner and see what it says... I just can't think of anything... I mean, I do remember when I pulled the intake I unplugged something and said to myself, "must remember to plug this back in"... I can not find anything disconnected anywhere, unless it is behind the intake where I can't see.. But, again, not going to pull it till I see what that scanner says..sigpic
Man I picked the wrong time to give up drinking...Originally posted by Darren View PostGood call, I would just put it in the back of your mind until you get the scanner and can see what that says. Just walk away let it cool down and then go at it with a fresh mind. You'll figure it out, and I am sure the scanner will help.sigpic
the gasket being visible is fine, remember the TB is only held on by 3 bolts, its best to torque them in sequence but it almost always looks like that no worries.Doing less with more
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
InActive Member
- 527
- dustin
- rothbury michigan
well if you need a hand or wiring diagrams i have access to my gm manuals on my lap top. just let me know...sigpic
Thanks Dustin.. Sent ya a PM..Originally posted by alwaysmessedup View Postwell if you need a hand or wiring diagrams i have access to my gm manuals on my lap top. just let me know...sigpic
