Originally posted by hoogiesngrinderz
View Post
Good bye LT-1....Helloooooo LS-1!
+1Originally posted by landstuhltaylor View PostWhy do you have to be so far away?
Yeahhhhh........ 4.5 hours of driving. You need to move closer. As of right now I think I am going to send it to Frost. I am still going to keep you as a back up Mike. I appreciate the offer.
So a few more hours of welding and cutting and grinding, oh my!
man, that was a pain. I dont think my welder survived. It wasnt doing so hot there at the end. Not bad for a Harbor Freight welder.I added the pad for the trans mount to sit on. That moves it back to its original position, it probably wasnt necessary but you cant be to careful. Soon as the paint is tacky, Its going in.Last edited by zeeman; July 11th, 2014, 02:01 PM.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
If I can get EFIlive from Darius, I can drive over. So far three people on this forum need 98 PCM's looked at/changed. I can do so at no charge for the PCM, I just need gas in the SRT4
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Yup, that. Enough to total most 4th gens.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Tuning for bolt ons is a shot in the dark IMO, but it's better than nothing. I street tune with wideband, usually get the main VE cells within +/- 1 or 2 percent. As for trans, I have a program that spits out pretty optimal transmission parameters based on gears and converter.Originally posted by zeeman View PostWow, thats a hell of an offer. I am going to have them tune for my bolt ons and tweek the trans a bit. Can you do that stuff too?
ok, sounds like a winner. when can we do this? You were saying something about the o.s. and the vin# earlier, will that pose a problem for future tuning? Like if I rebuild the motor and install a larger cam and need to retune it wont be an issue right? Ima pm you my cell # text is fineLast edited by zeeman; July 12th, 2014, 07:21 PM.
Here is the list to be deleted. Vats,egr,evap, airpump, rear o2's. It also needs speedo recalc. I would like the fans to come on at 160. I have been thinking about raising the converter lockup to 45 mph.
we would just be tuning for headers , and a stall converter. If you can do this we would be a go if the timing is good.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
I can build a tune tomorrow really quick. So 160 thermostat is in it now? Fan temps for that would be higher. What brand long tubes?
ok yeah, getting a little ahead of myself on the fan temp. That is how the lt was set up and it worked pretty well. but it still had a 180 T stat. I do want ot keep the temps a bit lower than stock. Maybee we could just lower the "fan on" point by 10 degrees? I am not sure whats in it now as far as the stat goes I will have to look and see. The long tubes are from Speed Engineering on ebay.Last edited by zeeman; July 13th, 2014, 02:47 PM.
I need to get a date for this Mike, What looks good for you? I'll be on afternoons this weekend, So I would need to be done by 3:00 to make it to work on time.Im off monday and tuesday , days shift wed thur and fri.
EDIT: Monday is no good I need to get the rest of the exhaust parts made up. Starter hung, and a couple other odds and ends done so, it'll be after that if we actually need to start it and run itLast edited by zeeman; July 13th, 2014, 02:53 PM.
It isn't hooked up to anything, so I could remove it or pull the fuse....but it really doesn't bother me since there are no codes
