Even less done today. Dropped off the harness for re pinning. Thats all folks. I need a break.
Good bye LT-1....Helloooooo LS-1!
Originally posted by zeeman View PostOh, decided to keep the evap for now.
Really? Why? That's like boring out 7 of 8 cylinders and calling it good. If you're going to delete emissions, might as well do it now...
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I don't get why everyone wants to delete EVAP. It doesn't increase performance and it isn't a big eyesore on LS1 cars, just a single line and a small solenoid.
Originally posted by hoogiesngrinderz View PostI don't get why everyone wants to delete EVAP. It doesn't increase performance and it isn't a big eyesore on LS1 cars, just a single line and a small solenoid.
Pretty much this. I can always tune it out and remove it later, its not a big deal. Its not a big hardware issue like airpump or egr valve, which effects the headers.
on the LT1 it junks up the engine, I wanted to get rid of as much of the "bloatware" as possible lol- Brian Meissen
Personally I just cut the EVAP line back at the driver's side wheel well between the wheel liner and the shock tower. Cover the opening with cheese cloth or something so bugs can't crawl in and call it good.- Brian Meissen
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Just run the pump. I put some fuel hose on the end of the line (in the engine bay) and pumped it into a couple 5 gallon fuel cans.
ok, I was able to siphon enough out, it wasnt an issue after all.
On to todays progress halting problem.....
I was able to get my car in the garage today and dropped the tank and lines. I installed the tank from the donor, however the plugs arnt even close. the donor tank has 7 wires on one plug and two on a different plug. the original only has 3 wires. Where did I goof on this? Something isnt jiving here. I cant put the pump in the old tank the lines arent right. Wtf are all the wires for on this 98 tank?
