Good luck!
stepping up to the LS2.... ditching the LS1
didnt get it done
had to tear into the front half of the tranny to fix a leak. had to wire in the lingenfelter control module and reroute/fix/wiretie the wiring harness for a nicer install. got stumped on what to do trying to mount the 98 perimeter style coil packs on to the corvette brackets. is there a different set of coil brackets i can make fit the 98 coil packs or is it going to have to be a custom job?? anyways motor and tranny are installed, brake lines done.... well all that is left to do is radiator, driveshaft, torque arm, exhaust, and a couple little odds and ends. im thinking another 3 or 4 hours and itll be done
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
you've made tremendous progress there. Don't be in too much of a hurry and miss somethingWhen in doubt, Whip it out !
are the truck coils better, whether it be 5.3 or 6.0?Originally posted by sman View PostI think your going to either need to fab something up or just get a set of newer style coil packs and brackets. I dont THINK you can put the 98 coils in the newer brackets. But ive only used truck style coils, so IDK for sure.sigpic
1998 Formula
They will fit fine I still have my original 98 coils the mounting points on the car coils are the same, the trucks may be different.Doing less with more
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
