stepping up to the LS2.... ditching the LS1
  • #76
    pics of parts?
    00 Tahoe Z71........Stock
    • #77
      Parts is good!
      • #78
        Originally posted by TylerT/AZ28 View Post
        pics of parts?
        pics of it going back together. i just got some headgaskets and other random gaskets. also got the lingenfelter crank sensor trigger conversion module so my computer will read the 58 tooth reluctor wheel. dustins getting my headbolts. performance parts i already have. but ill try and post some pics sunday as its going back together. stall is being rebuilt so tranny cant go back in probably until the follwing weekend and thats when we can try and fire it up
        • #79
          Ill post some pics tonite
          • #80
            of what? some bolts lol. or some pics of how dirty the car is as its sitting?
            • #81
              Tits or GTFO!
              Originally posted by Yoshi94
              • #82
                tomorrow we start assembling and reinstalling
                • #83
                  Good to hear you're getting it back together Mike. Quickly too!
                  • #84
                    Well I hope all goes well Mike. Looking forward to seeing some pic's, even if its just a box of bolts. LOL
                    • #85
                      update. well i guess when you order headgaskets and waterpump gaskets, its best if you order "two" of each lol. didnt realize that quanity of 1 meant just one, and not a set! so got one head installed and reused my "slightly used" waterpump gaskets. pulled the bad ls2 cam and cam gear. installed my cam and the new cam gear, timing chain, pickup and oil pan installed. got the front accessories on and one head. swapped over motor mounts and what sensors were needed on the ls2. dustin is going to get the other headgasket, then i can get that on with the intake and be ready to set the engine back onto the k member. my stall is on its way back after a rebuild and should be here by this weekend. not going to rush it but i may actually get to fire the car up this coming weekend if everything goes well. took a couple pics but none turned out well and then the cameras battery died. oh well, we all know what we would have seen
                      • #86
                        Sounds like your coming right along! Keep up the good work!
                        • #87
                          Hope it continues to go back together smoothly for you!
                          • #88
                            so far so good. sunday is looking good
                            • #89
                              today is the day. will we get to fire it up?? im hoping so
                              • #90
