stepping up to the LS2.... ditching the LS1
    Early ls2 were 24x with a smiley face gear
    later went to 4 bolt 58 with a 4 window
    Later engine then went to a 4 window 1 bolt gear like you posted.
      wow glad we figured this out. thanks guys
        06-09 Impala SS, 05-08 Grand Prix GXP, 06-08 Monte Carlo SS, all came factory with 243 casting heads on the LS4 5.3's. I would imagine you could find one wrecked and get the heads pretty cheap because most people dont know they came with those heads.
          A lot of the new silverados with the 5.3s have them too. Makes them a lot easier to find in a junk yard. 799 is the same as 243 btw.
            after having to upgrade valve springs i dont think id be very far off larrys price although. thanks though guys. i appreciate it
              im excited to move on to bigger and better things. spring is coming fast. im hoping the ls2 will be just what the doctor ordered. im praying i have no issues with this setup. i just want to be able to drive my car this summer. ill even keep it off the track if need be. picking it up next weekend and cant wait to get started putting it together.
                Sounds like a good plan!
                  I'll be putting up my 243 heads for sale soon, if my plan falls through though. Complete heads not bare.
                    Sell your ls6 intake for a ls3 intake. I will make you brackets to adapt your stock ls1 rails on the ls3 intake if you need. Than find some used l92/ls3 heads and get 8 ls3 intake rocker arms and trays for both heads. You wont be disappointed. It will shroud the valves a little they say but for the top end power you will get you will never look back. If it is done right and with a little luck it will not be that expensive.
                    http://www.gmhightechperformance.com...s/viewall.html - Dont take my word for it either. Look at torque under the curve compared to the ls2 heads. There is nowhere that the cathedral out performs the square port period. I firmly beleive all the shit regarding square ports killing low end power/under curve/valve shrouding killing power is just myth. I have yet to see a set of these not perform on any application. Not saying there arent better options available but for the price you cannot go wrong.
                    That is just my $.02 I would use the 4" bore to your advantage, either way I am glad to see you got a new motor I am sure it will scream either way. Good luck.
                    99ws6 - Huron Speed Turbo - PT67
                      ask dr phil about rectangle ports.
                      make more power with cathedrals every day. rect wont rev
                        I wonder why they wont rev. I have seen these make alot of power cam only as well as h/c. Off topic but what about under boost? These big runners move air under pressure no doubt. I am not disagreeing with what you are saying but I have seen these motors run hard. Do you think the cases Phil ran into were mis matched parts or another reason why they would not rev. I have heard that they are picky on cams as well. Cathedral cams do not work worth a shit on these heads. (so I have heard but I dont know why somebody wouldnt match a cam in the first place)
                          they require cams with a big split because the intake to exhaust ratio absolutely sucks. the intake runner is also so large that velocity is an issue . cause drivabilty and low torque down low
                            Are you talking split on lobe seperation or split on the duration of the intake to exhaust? The cam I ran has a way larger exhaust duration than intake duration on a high lsa with -4 degrees negative overlap. I figured that was the logic behind the spec. Hold the intake valve back a little bit to keep the air moving not kill all velocity while getting exhaust out as fast as possible.
                            It makes sense that they would suck balls down low but I still see good results for God only knows why. My car feels solid down low as well without any boost whatsoever on it. Although there is no down low comparison to what I had before with my old 250cc cathedrals lmao.The car did not run below 4500
                              My father still has his LS3 short block (crank rods pistons block) with the heads and valve train that came out of a Vette still sitting at his shop in Fraser on a pallet. It fully assembled and turns over by hand. The valve cover was popped to confirm it was an LS3 valve train. All you need is the intake, tb, injectors, computer, harness accessories and brackets. He always said if someone offered him what he got it for he would take it. I'm not sure what your budget is or how deep you are with this LS2, just figured I would give you more options. Sorry about your bad luck with the LS1, that sucks bad.
                                my ls1 cam (comp cam 232/232 .587 112lsa) will work in the ls2 right? using the 243s. i really dont have cash to find one of those also.
