stepping up to the LS2.... ditching the LS1
  • #91
    Good luck!
    • #92
      didnt get it done had to tear into the front half of the tranny to fix a leak. had to wire in the lingenfelter control module and reroute/fix/wiretie the wiring harness for a nicer install. got stumped on what to do trying to mount the 98 perimeter style coil packs on to the corvette brackets. is there a different set of coil brackets i can make fit the 98 coil packs or is it going to have to be a custom job?? anyways motor and tranny are installed, brake lines done.... well all that is left to do is radiator, driveshaft, torque arm, exhaust, and a couple little odds and ends. im thinking another 3 or 4 hours and itll be done
      - - 5.3/4L80e/T7875 - -
      - Huron Speed Turbo Kit -
      1998 Formula
      • #93
        I think your going to either need to fab something up or just get a set of newer style coil packs and brackets. I dont THINK you can put the 98 coils in the newer brackets. But ive only used truck style coils, so IDK for sure.
        • #94
          you've made tremendous progress there. Don't be in too much of a hurry and miss something
          When in doubt, Whip it out !
          • #95
            are the truck coils better, whether it be 5.3 or 6.0?
            1998 Formula
            • #96
              Yes, higher output. "Supposedly" anyway. There is a big long thread on tech about it. I believe the LS2 actually uses these same coils. They are round and have a heatsink on top.
              • #97
                The coils are not the issue just get the center bolt brackets
                • #98
                  I know, but his coils wont fit in center bolt brackets right?
                  If so, then he would need new coils/brackets or have to fab something right?
                  • #99
                    They will fit fine I still have my original 98 coils the mounting points on the car coils are the same, the trucks may be different.
                    • ok, guess i was confused. Because according to post 92, he couldnt figure out how to mount them.
                        As far as I know 98-02 LS1 Fbody coils are all identical.
                        • ordered the correct brackets
                          1998 Formula
                          • You didn't Ask for those. Think I have a set somewhere
                            • i thought the set i had at home would work so didnt think id need em. im getting new ones for $30 so its not too bad. thanks though larry
                              1998 Formula
                              • It lives and sounds pretty good. He drove it home tonite, still waiting for my ride.
