Originally posted by LPE 403
View Post
<Project> 2000 Trans Am
negative. maintain the lenses as you would on your paint and they'll always look good! its funny if you think about it. you'll polish a car for hours and lenses will take minutes. acrylic lenses are harder than your clear as well....the clear on your paint will scratch easier.sigpic
Well that clears up that issue! Thanks BretOriginally posted by LPE 403 View Postnegative. maintain the lenses as you would on your paint and they'll always look good! its funny if you think about it. you'll polish a car for hours and lenses will take minutes. acrylic lenses are harder than your clear as well....the clear on your paint will scratch easier.2000 Trans Am l 1967 Firebird
Wet-sanded to 1600 or 2000, can't remember which. Then I took them to the machine shop that I used to work at. They have a couple of stand up buffing jacks that look like this...Originally posted by ThreeHonks View Posthow did you polsih your lights fred?
and use wheels similar to this...
Now, with wheels like this you apply a hard compound to the wheel while it is spinning. The compound comes in "brick" form and gets transferred into the fabric of the wheel when you touch it to the wheel. These compounds come in different variations of "coarseness", so just like sanding - you start coarse, and work to fine. The same is true for the wheels, there are different materials with different textures.
Buffing metals with a machine like this is truly an art. I have light experience in this practice, but can do a decent job. It is mostly meant for polishing metals like stainless steel, or plated metals like chrome.
So basically when you're buffing an object, the compound transfers from the wheel to the part, and will build up in crevasses and other such lips and forms. I had a lot of "thrown" compound built-up around the lip of the reverse lights. That's when I hit them with lacquer thinner and shortly after, felt like throwing up.2000 Trans Am l 1967 Firebird
dont remember 1.5 coils maybe. cut 1/4-1/2 coil at a time until i got what i wanted.Originally posted by Purple94Z28 View PostHow much did you cut the back springs? what is the advantage of a v6 spring? i heard they are nice to have for the strip?
sorry about hijacking your thread fred...
98+ v6 rears are the same as ls1 v8's. people use the softer springs to get the rear to squat. but girls squat , race cars should not.
if set up correctly they really dont do much
fred your tailight polishing is still up on this thread right, with pics?
here is also something I forgot I had, if it helps any for ryan
http://www.thirdgen.org/techboard/fa...polishing.html99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
Yes, probably a couple hundred posts back or soOriginally posted by Gottork View Postfred your tailight polishing is still up on this thread right, with pics?
Good thread on TGO
sorry did not mean to post useless info..lmaoOriginally posted by Lucky SOB View PostYes, probably a couple hundred posts back or so
Good thread on TGO
but yeah I saw this and REALLY enjoyed your break down of the polishing so thought maybe this could add to your repertoire
your not having any luck with tailights buddy
sorry99 Buick Regal GS- New DD
