Originally posted by Gottork
View Post
<Project> 2000 Trans Am
good stuff man, very nice99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
Originally posted by ThreeHonksI like having a loud car, every time the neighbors dog barks, I just go let my car sit and idle in the driveway
Rear End Revival: Day 1
I tore down the rear end today. I got all the wires, brake lines, rotors, calipers, sway bar and panhard bar off and ready for paint.
I then popped off the differential cover and drained the fluid - pretty black, but no metal
I've been searching LS1tech trying to figure out what differential I have and it sounds like I have the LSD...
Basically,
I turn the yolk, both rotors spin same direction
I turn one rotor, the other spins the opposite direction - the yolk doesn't move
Can anyone verify that I have the LSD?
My next question is the fluid...
How much do I need to put back in? I bought 2 quarts of Royal Purple Synthetic and a friction modifier additive... Do I need this? and how much?
Should I attempt the clean the inside of the differential to get the old fluid out? Some people on tech said to use brakleen... opinions?
I sandblaster the differential cover to get the rust off, and in doing so, the magnet fell off. It appears to have been glued/epoxied on from the factory. I'm sure the engineers did this for a reason - anyone know what product I can use the reattach it? I don't feel safe with just trusting magnetics...
What I started with...
What I ended with tonight...
Can someone please tell me what differential I have?
Differential cover after blasting... with magnet
I think you can clean it out with brakleen, but there are more people here who would know better than me, looking good man99 Buick Regal GS- New DD
Why wouldn't you have an LSD? All 4th gens came with them. You might be thinking of a Torsen vs an Eaton differential? If so, take a look inside the diff, if there are gears in there it is a Torsen, clutch packs are Eaton. From the pics you posted I can't really inside the diff, but looks like an Eaton case. But don't quote me on that, I don't work for Torque
Edit: I think you just fill it through the fill hole until it comes out just like the t56Last edited by my95z28; January 9th, 2011, 10:37 PM.
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
i dont have a clue but ill trade yaOriginally posted by Lucky SOB View PostCan someone please tell me what differential I have?
All ls cars had LSD. Your looks to be a torsen to me, I know the 98s had auburn diffs. Brake cleaner works well to clean it all out.Doing less with more
Yep all 4th gen V8 cars came with some form of a limited slip diff. 98s had the auburn clutch style and somewhere after that, they started switching to the torsen style, they dont really wear out, they just kinda break and stop being an lsd. You do not need the limited slip additive in the Torsen setup, but it doesnt hurt it any.1999 Camaro - 6 liters of fury.....
Thats how I did mine.Originally posted by my95z28 View Post
I used gorilla glue to hold the magnet on, and black silicone around all the edges of the magnet.
Have your gears ever been changed? Was there ANY metal shavings on the magnet?1998 Chevrolet Camaro Z28 - 6 Speed
Thanks guys!
Gears are stock 3.42s and zero metal shavings on the magnet or in the pan.Originally posted by nascarnate326 View PostThats how I did mine.
Have your gears ever been changed? Was there ANY metal shavings on the magnet?2000 Trans Am l 1967 Firebird
Are you going to do a gear swap? I have some used 3.73 gears you can have if needed.Originally posted by Lucky SOB View PostThanks guys!
Gears are stock 3.42s and zero metal shavings on the magnet or in the pan.sigpic
Looking goodThe Original
