Rear End Gears
    Originally posted by Fox Slaughter View Post
    http://www.f-body.org/gears/
    1st gear with a 4.10 at 5700rpm is 40mph.
    6th gear with a 4.10 at 70mph is 1900rpm.
    Damn - in my 2012 1st gear at 5700rpm is like 15mph...
      Originally posted by Boost Addict View Post
      Compare 6th gear of a T56 to 4th of a 60e. .5 vs .69. Overdrive in the 60e is pretty close to 5th in the T56.
      For some reason i thought 4th was 1:1 on a T56??
        Nevermind i read your post wrong. You can compare 4th gear in a t56 and 3rd in a 60e since they are both 1:1
        2.66---1.78---1.30---1.00---0.74---0.50
        1:1 in a 4L60e is 3rd
          Go big! I ran 3.73's on my old 4th gen and wished I had gone to a 4:10 instead.
            early t56 6th are .62
              now how bad are 4:11's going to screw with my idea of having a low end powered car.
              1997 Trans Am
              T56 swap. LS1 Cosmetics
                If you can drive a T56 they will do nothing but help you
                2015 Silverado
                  Rear End Gears
                  It'll be my first 6 speed car.. I've only driven 5 speeds.
                  1997 Trans Am
                    Final drive doesn't change much, just adding a gear.
                    First gear ratio is what you want to watch out for. Early v8 T5's had a lower 3.35 gear (if I remember right) and wasn't so bad with 3.08 or 3.23, but 3.42's were on the verge of having a quick 1-2 shift. Later T5's worked well with 3.73 because of a 2.95 first gear.
                    Rule of thumb says that staying close to 11:1 or less in 1st is ideal for street use. Early T56 had 2.97 1st gear ratio and with a 4.11 rear would put you at 12.2, while a later T56 with the 2.66 1st would be 10.93
                        It should be noted that the 2.66 1st gear ratio applies to F-Body T56's '94+, the '93 model year had two different iterations of the T56, the first gear ratios being 3.36 and 2.97. These were M28 and M29 T56's.
                        Nick H.
                        Current MIFC Vice President
                          Good info! Wasn't sure of the years, haven't rebuilt one yet so my knowledge is limited on that trans
                            im pretty sure its a 94+ if memory serves me right its from a 96 WS6.
                            Also are these a good set to go with ?
                            http://www.summitracing.com/parts/sag-g75411/overview/
                            EDIT: i cannot find any 4.11's for a series 2 7.5
                            1997 Trans Am
                              How hard are you going to be on it?
                              I'd run a 3.90 gear - many have had better luck with them lasting in a 10 bolt. They are much stronger compared to the 4.10's.
                              2000 Formula
                              fixed slow junk
                                I wouldnt say hard at all, maybe once a week i get on the gas a little have some fun on the street but not much over 1/2 throttle.
                                1997 Trans Am
