Looking to get my T56 swapped in shortly, and decided then would be a good time to change the out the rear-end gears from 2:73's. At first i wanted to go all out to 4:10's but i actually want to use first gear
So what are you guys running?
No it was butter with the Spec 2+ I had. It wasn't as fun with a Spec stage 3 though. And yes the .01 does make a difference. It turns the gearset into a hunting gearset, and they wear better.
2015 Silverado
Where can I find nice 4:11s? I've only seen 4:10s but then again I haven't looked very hard. And I'll have a centerforce dual friction with aluminum fly wheel.
