Snyders 350 Sludge Block Chevy
  • Snyders 350 Sludge Block Chevy
    Hey, spent some time pulling Snyders motor out tonight, had a ticking noise in it after we put the headers / dual exhaust on and gave it a few revs. So its getting a little overhaul / cam swap, etc.
    So, in a heat of a redneck moment, his dad just plucked the motor out with a CASE skidsteer, lmao.
    Aparently the previous owner thought that a combination of thick gear lube and sand, would make a great motor oil!
    Glad you guys took a look at it thats some nasty stuff.
      " So, in a heat of a redneck moment, his dad just plucked the motor out with a CASE skidsteer, lmao."
      Haha. It's not that redneckish. But yeah the ol' 350 has definately seen her better days. Yeah I don't even know how that much shit would have gotten in there. Maybe it sucked up charcoal from the cannister? I don't know I've heard of that happening, but there was alot of shit in my engine.
      Holley 650cfm Double Pumper
      Edelbrock Performer-Plus Cam
        It woulda sucked it into the cyl and just spit it out the exhaust, not into the lifter valley lol.
          damn that's got some buildup in it!....i don't think SeaFoam woulda cut it either
          well once it gets cleaned up and you do what you're gonna do...it should run a million times better!...oh and about the "redneck cherry picker"....we used to use a fork lift at my step-dad's old shop, it also doubled as a hoise LMAO...(it was one of those gigantic ones)
          anyways...can't wait to see new pics when it's done!
          1998 Camaro SS Bullseye Turbo
            Yeah I'm still kind of undecided as to what I'm going to do. Rebuild this one, turn this one into a 355, or buy a fresh 383 with a spun bearing and have that fixed up.
              What other surprises await when you get deeper into the motor you have?
              If you rebuild the one you have, it would be easy to turn it into a 355.
              But once you get the 355 in, you'll be wishing you had the 383.
              JMHO, there is no substitute for cubic inches.
                wow that is nasty. but glad you caught it and are taking care of it know before you blew it up. While you have it out you mid as well rebuild it!
                  Damn that's nasty!!
                    I've plucked some engines outta the junkyard that didn't look that bad. I can honestly say, that is the nastiest lifter valley I've ever seen, as far as sludge goes.
                    As far as what to go with, a 383 will probably cost the same as the 355. I personally if I was going to build a std stroke 350-355 I would go with 6" rods and give it a better rod/stroke ratio. However 383's are easy to build now and the low end you will have from that motor will be great on the street.
                      That's pretty ugly lookin there.
                      — Thomas Jefferson
                        Gross! Clean that 350!
                          someone didnt use engine flush during oil changes..lol just pour like 5 gallons of kerosene in it and turn it over a few dozen times it will be fine... lol just cleaning it up will gain you 50hp... my god that is pretty nasty ive seen engines half apart lying in the mud cleaner than that... just goes to show the chevy quality....
                            damn dude, thats nasty! time for a 383!
                            2011 Cadillac CTS-V sedan black raven 6spd
                              cheap engine oil.
