Alright. I'm also going to do the free ram air mod to push even more air. Seems like I'm running a little rich. So I'm going to try and stuff a lot of air Into the system.
Also anyone have a pic of how the ss hood grill is setup? Weather its inside or outside of the scoop?
2002 Z28 Camaro A4 1993 Z28 Camaro M6- SOLD 1999 Z28 Camaro M6- SOLD 2008 Ford Fusion SE - DD
Quit complaining get it to the size you need. Use some glue in the corners then use a cost hanger and pull it into spot.
And mcalus do you have a spare lt1 can laying around?
Bigger then stock?
cam? No just the stocker.
Post up in the wanted section on LTXtech and ls1tech. You'll find one in no time.
For couplers just go to lowes or Home Depot and go to the plumbing section and and pick up a 3" fernco coupler. You're going to need to trim the Inside to thin it out some, so it fits over the LT1 throttle body. But that's all you need to connect the lid to the throttle body.
Don't use fernco. It's stiff as hell and looks like it belongs on a pipe - because it does! A piece of silicone hose isn't much more expensive.
