ls1 lid swap on lt1 with 98-02 front end?
    Alright. I'm also going to do the free ram air mod to push even more air. Seems like I'm running a little rich. So I'm going to try and stuff a lot of air Into the system.
    Also anyone have a pic of how the ss hood grill is setup? Weather its inside or outside of the scoop?
      Inside
      2002 Z28 Camaro A4
      1993 Z28 Camaro M6- SOLD
      1999 Z28 Camaro M6- SOLD
      2008 Ford Fusion SE - DD
        well thats going to be a very fun install,
          Quit complaining get it to the size you need. Use some glue in the corners then use a cost hanger and pull it into spot.
          2002 Z28 Camaro A4
            Wouldn't have thought of that thanks lol.
            Anyone have a few couplers laying around?
            And mcalus do you have a spare lt1 can laying around?
            Bigger then stock?
              Bigger then stock?
              cam? No just the stocker.
              2002 Z28 Camaro A4
                Got any leads on a used one in good shape?
                  Post up in the wanted section on LTXtech and ls1tech. You'll find one in no time.
                  2002 Z28 Camaro A4
                    For couplers just go to lowes or Home Depot and go to the plumbing section and and pick up a 3" fernco coupler. You're going to need to trim the Inside to thin it out some, so it fits over the LT1 throttle body. But that's all you need to connect the lid to the throttle body.
                    1997 Trans Am
                    T56 swap. LS1 Cosmetics
                      Alright thanks
                      Is 60$ a good deal for a SLP air lid used?
                        Alright thanks
                        If its in good shape, and that's as low as the guy will go. Then yeah.
                        1997 Trans Am
                          Don't use fernco. It's stiff as hell and looks like it belongs on a pipe - because it does! A piece of silicone hose isn't much more expensive.
                            He's over 3 hours from me. So he's going to ship it. For me.
                            And he's giving me the rubber throttle body hose
                              That hose is going to be a life saver man, good luck. Make sure to post some final product pictures.
                              1997 Trans Am
                                I will. Hopefully it works out like I hope lol
