I'm all out of ideas. I hardly drive the car anymore because I frankly can't trust that it'll start. If I haven't driven the car in a few days, I have to trickle charge the battery over night if I want to drive anywhere the next day. I charged it on Thursday night, drove Red Alert to work on Friday, then drove around a bit on Saturday. As I was leaving one of my errands, the car hesitated to start and I knew it was the symptom I was familiar with. I immediately drove it to O'Reilly, they hooked the tester up and I started the car with no problems and everything tested out OK. I went inside to buy some detail spray, came back out and the battery was dead and wouldn't start. The guy who tested the car came out and gave me a jump and sure enough it started right up. He thought maybe the battery was too small but I have the biggest amp battery they have so it should have no problems starting my car. When I went back outside to leave, sure enough the battery was dead again and I needed to be jumped again just to make it home.
We've replaced the starter 4 times thinking it was the starter that kept getting fried. Now I have a new starter with a heat blanket AND a heat shield around it so I know it's not getting heat soaked by the long tube headers.
The red top optima that I have was bought March 2010, so it's not that old.
Every time I've taken my car to O'Reilly, they test the battery and the alternator and everything comes out OK.
The night I was out on Woodward and needed to be jumped by that puny 305 (
), the whole way home FreeScan was saying that the PCM was continuously seeing around 12v which is way too low - yet when the guys at O'Reilly hook the tester up to the battery, they don't seem to notice anything wrong with the voltage? Though I can't remember if they ever mentioned it being wrong...
We think something is draining the battery because my battery is typically drained after 2 days. We're not sure what it is that's causing it, though. I bought an ammeter/voltmeter combo from E-bay but when the car is off the ammeter (wired inline with the battery's positive terminal right at the battery) reads 0.00 draw the moment I open the door. This doesn't make sense - if something was draining the battery to the point that it's dead within 2 days, I would think the draw would be large enough to register on the ammeter.
We had the same problem when RA's heart was the V6. This means that it rules out basically any wiring for the battery directly since it's a completely different wiring harness. What it DOES NOT rule out would be anything in the INTERIOR HARNESS. I would think it also rules out the alternator being bad because it's not the same alternator as the v6 had.
Cliff notes:
- Battery drains within a few days while parked
- Battery replaced in March 2010 with new red top optima
- Replaced starter 4 times, current starter has blanket and heat shield
- Voltage via OBD1 port reads LESS THAN 12.5V while running
- Happened while v6 and v8
-- rules out the alternator (two different alternators)
-- rules out wiring to the starter (two different wiring harnesses)
-- rules out wiring to the battery terminals (two different wiring harnesses)
-- does not rule out any electronics under the dash
- Battery and starter (WHILE ON CAR) always test OK when I drive to O'Reilly and have them test it.
Cliff notes:
