The only time the light should be on is if you have the door open, hood light on because it is open, or your glove box door is open.
Remember you are putting the test light in series with your battery lead not across the battery in parallel.
If one of the Diodes inside the Alternator was shorted, this can also drain the Battery, but the Alternator will still put out the correct Voltage, and therefore pass the Voltage Output Test, however it could not put out full Current, and would fail the Current Load Test, if the auto parts store actually ran that test.
