Project: PBR-Built Z/28
  • Do me a favor. Unplug your connector above the fuel pump on the bulkhead for the wheel sensors and let me know if your brake light comes on. Mine is on and I wanna know if its that or something else in the brake system. Fluid level is full. But might be something else in the system.
    Originally posted by Yoshi94
    • New stance looks good Joel. Wish I would have done the ls steering shaft while mine was out. Meh..
      2002 Z28 Camaro A4
        Steering shaft is only necessary if your stock rag joint is worn out. Mine was still snug when i bought the car (75k miles... But now at 104 it was shot).
        • Looking good as usual! Looking forward to some auto-x vids.
          • Stance enhances the look of the car a ton, nice work! Looks awesome!!!!
            • Stance is perfect!
              • looks good joel!
                • Cowboy up and get that tint done
                  2015 Silverado
                  • Re: Project: PBR-Built Z/28
                    Looks great! Are you allowed to have passenger during auto x? Its something I would love to get into. Going straight gets boring quick haha.
                    • Project: PBR-Built Z/28
                      Car looks awesome. That SS hood is SEXY!
                      1997 Trans Am
                      T56 swap. LS1 Cosmetics
                        Joel has an SS hood noob :thumbup:
                        • Since you did the tuning Joel it sounds like you tuned it to compensate for the air leak, no? I forgot - is your tune open loop or closed loop?
                          • Absolutely looks great - stance looks perfect to me!!
                            • Thanks everyone! Yes Rolo you can have a passenger i give rides all the time. Im very excited to autocross this thing now that i dont have to tip toe on the gas the entire lap to avoid wheel hop - shes solid! Only thing i kinda forgot about that i want to test is the posi... Now that this thing has some kick ass suspension im afraid its going to want to peg leg the 104k mile posi out of corners.
                              Yeah this leak would have been there from the beginning. It is closed loop so Technically the pcm should be able to adjust to fixing it but i just have my doubts about it anyway. Im going to disconnect the battery to reset the pcm and give it a try. I think ill definitely need to at least raise my idle since i set it low with the vacuum leak, itll probably want to stall at idle with it capped.
                                That's what I said stupid auto correct lol.
                                1997 Trans Am
