Project: PBR-Built Z/28
    That's what I'm running!
    Though, when I feel like it, I'll probably switch the rears out to bilsteins as it's a much easier swap than the front and I can't carry much more than 100+ lbs without the tire hitting on larger bumps.
    Ill have to look at prices... Id like whatever i get to work but ultimately im goin to change it all to koni's and tubular everything down the road.
      i dont think i want to go quite as low as yours. Im iffy on stranos they seem to ride a little high.
      Mine doesnt sit that low now that it has correct sized wheels on it. No matter what, I still need to help repay you for the header install we did over a year ago.
      Everything has settled now.
      • That's a damn nice stance, Nate. What's your setup?
        • Eibach Pro kit with Monroe shocks. It turned out perfect IMO.
          Id take this setup over Kyles Strano/Hothkis(sp) set up any day.
          • unfortunately im afraid id be dragging exhaust around every other corner of grattan if i went that low.
              Huh... I have the Pro Kit too. Damn yours sits perfect.
                Mine sits pretty low. I have Bilsteins and Intrax springs. It's amazing how driving down a bumpy road can make you pretty uptight
                • Joel would you consider cutting your stock springs?
                  If you didnt like it you could have my front LT1 springs (fred idk if yours are different).
                  I wanted to try it but couldnt pass up the deal I got on mine.
                    Strano/ Koni
                      I think if I am lowering the car I should have a spring with a higher spring rate as this will be performance driven. Nothing against cut springs, but i don't feel like taking it all apart and aligning it just to go through it all over again.
                      • If this is for handling, you might as well just go with coilovers. Expensive, but extremely effective. Or Konis with a good spring.
                          Im the biggest suspension newb ever... Whats the difference? I thought the factory setup was a coilover??
                            The factory setup is technically a coil-over setup, yes. I should've been more specific - go with an adjustable coilover setup, thus the last part about the Konis was mostly redundant.
                            • Ok so basically the key difference you are referring to is the spring/ride height would be adjustable?
                              • Well, Konis have adjustable damper and rebound settings.
                                A straight adjustable coilover will generally allow those settings, along with a ride height adjustment.
