Originally posted by M_Juntti
View Post
The duration @ .050 that you need to worry about is .242/.248 @ .050.
This is the SAME cam that is in Red's car that we used for her 383.
420 hp N/A with a 6-speed.
And the 227 heads are made to fit the LT4 intake ONLY!
And this would be a concern for me right here!
This is straight from AFR's site: http://www.airflowresearch.com/index.php?cPath=27_32
Standard rockers can be used but the intake rocker arm will be at a slight angle and the roller tip will not be perfectly centered on the valve tip.
Not recommended for street use, unless shaft mount rocker is used.
Hope you have some serious cash laying around because a shaft system is 1000 +.
It sounds to me like just a bunch of name brand parts slapped together.
