steering wheel shakes at 70mph plus. bad vibration upon slow down
Do uou guys know if the ls1 front rotors work for lt1 front brakes?
Cause I have a set I was going to put on once I did my ls1 front brake
Conversion. But never had the chance to get calipers.
And I'm thinking warped rotor and balance. Ill have the rotors
Checked to see if they're true or not.
anytime the tire is unmounted from the rim they should get rebalanced, if the tire takes a huge amount of weight on one side, unmount the tire and rotate 180* then rebalance. while you have the tires off the ground check for play in the steering and ball joints.
