Dan's 97 Camaro part 2
  • #76
    I'm getting 160 mV at the coil harness connector with the key on. I think I found my problem
    • #77
      No tach, but no care
      • #78
        Lol, good job Dan !
        • #79
          Thanks Joe!
          • #80
            Congrats!!! It's a great feeling when she fires up!
            • #81
              Put coolant in and started to bleed the system when I broke a bleeder screw. Started it anyway. Had to fether the peddle to keep it idling. Started to smoke and I cut it off. Could have just been coolant splashed on the headers. Not sure yet.
              • #82
                Won't idle, driver side header is cold vs passenger side is hot. Has a slight miss and backfires on startup.
                Going to change the plugs wires.
                It however, does sound pretty God damn wild.
                • #83
                  Nice, who's tuning it?
                  • #84
                    Moe Bailey did the startup tune, will have it street tuned by a friend of a friend possibly or Solomon.
                    • #85
                      Bought an aem wideband.
                      7/8 plugs were fouled but 8/8 smelled of gas. I'll see how it runs tomorrow.
                      • #86
                        Update on the ol camaro.
                        Day 2 of running beautiful.
                        Pulls hard.
                        Running an open y pipe, cam sounds great.
                        Brakes work, abs doesn't lol.
                        Have a bad pulley somewhere too.
                        Overall, I am extremely pleased with what I have done to it. Now to just make the engine bay pretty..
                        • #87
                          • #88
                            Sounds healthy! Wanna grab a lane? You did good work if you changed all that stuff and ended up with minimal problems.
                            • #89
                              Thanks Joel! I'd love to grab a lane [emoji14] I'll be at Milan on the first for a college shootout. You should go and represent OU lol.
                              I am really happy with how easy the 24x turned out. Once I figured out the coil harness being backwards, it was set. Under the hood it's extremely messy but I'll fix it in due time. If I ever do it again I'm pulling the harness out to make it a little easier.
                              • #90
                                Car has a slight miss when putting around. Made new wires and replaced the header gaskets after I forgot to tighten them.
