1991 Camaro RS - Turbo 3.1l Project
  • #76
    I'm sorry I didn't get the chance to really talk to you guys at the m&g. Glad to hear that you are getting the tuning thing down though. It's probably a tire shredder on the 5 pounds lol
    • #77
      Thank you guys I really appreciate it!
      1991 Camaro RS: "Tiny Turbo Mullet"
      • #78
        Car is running pretty good now, boost is set at 10 psi. My injectors are around 80% duty cycle at WOT, glad I picked up some 48lbs a couple weeks ago. Probably installing those then increasing the boost some more. Car feels somewhere around 230-250 whp, not sure on torque. Hopefully going to get a run on the dyno at my college soon to get some numbers.
        • #79
          Nice! Don't go too crazy on the boost.
          • #80
            Against Dave's better judgement the car is set at 11.5 lbs of boost
            Pulls pretty good, no knock, afrs are fantastic. Car is idling much bettter, still a little rich though (14.2). I'm happy to say I have finally got all this tuning figured out. I want to work up the boost to around 15 psi, get a solid tune, and then back it off down to 10 again. Would like to take the car out to milan and see what both tunes run so I have a good idea.
            • #81
              • #82
                Car is running pretty good, put the 4th gen rear end in. What a world of difference. Solid LCAs and a founders adj panhard bar and the wheel hop disappeared!
                • #83
                  Excellent!
                  Does the 4th gen have the Zexel Torsen diff in it?
                  • #84
                    I believe it does, but to be honest I had no need to pop off the girdle and check. It was from a 2000 camaro, so it should.
                    • #85
                      Yes, the '98 - '02 LS cars have it. A very robust piece, so you should be good-to-go!
                      • #86
                        Didn't some catfish 4th gens have the Auburn, some have the Torsen?
                        • #87
                          99-02 only
                          • #88
                            Originally posted by landstuhltaylor View Post
                            99-02 only
                            Thank you.
                            • #89
                              Well this pile is getting LS swapped. I caved...
                              Looking for a 4l60e and converter. I just picked up a 4.8 with 120k miles on it complete. Goal is to have it done by next spring and make 450-500 wheel horsepower. The V6 has been a lot of fun but it is time for something new.
                              • #90
                                Wow. That's a change alright.
