Twin-Disc. Spend all of the money!
Dan's 1997 Camaro, aka project "NYTRDR"
Dan's got some awesome shifting skills you guys, haven't you seen his shift light!?!?!sigpic
- January 14th, 2015
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Troy and Port Huron
- Full time student
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
I've read quite a bit of great things about those. Thanks the suggestion!Originally posted by 97firehawk View PostI've had great luck with my ram power grip HD clutch and aluminum flywheel .
Sent from my SM-G900P using Tapatalk
I'm shifting a lot better now than I did 5 weeks ago.Originally posted by Atrus View PostKeep in mind, Joel shifts just a little faster than most...I've seen those youtube vids, Joel
TroofOriginally posted by JoeliusZ28 View PostRaces are won and lost on the time spent between gears
You offering to buy? McCleod twin disk.. Mhmmm money money..Originally posted by MP81 View PostTwin-Disc. Spend all of the money!
If only I had one of those LS engines! Then I could be like..sigpic
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
Not necessary for a LT1, youre not trying to manage 620hp and keep stock driveability. A competition 3/4/5 clutch will work just fine for you.-Joel
Well, then the most appropriate solution seems to be to swap an LS3 or LS7 into it, and then go with the Katech-adapted LS9 clutch package.
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
If you have $26,000, go for it.Originally posted by DanDalessandro View PostWhy not just a ls9?
http://www.chevrolet.com/performance...gines/ls9.htmlGone but not forgotten: 1986 Chevrolet Camaro IROC-Z
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
One stop shop here...has almost everything you need. Short block, clutch....
http://ls1tech.com/forums/parts-clas...aster-etc.html
