I had gotten the adjustable one. My car is lowered, and the rear was not perfectly centered, when you change the ride height you will change the location of the rear, so I figured Id spend the extra few bucks, although certainly no need for it if you dont plan to lower it much.
Dan's 1997 Camaro, aka project "NYTRDR"
My 93 was way off when I lowered it. It really helped having an adjustable one when I needed all the clearance I could get on both sides when trying to squeeze the widened 10 spokes back there. For the little of extra money it is, it's worth it imo.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Post Whore
- January 14th, 2015
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Troy and Port Huron
- Full time student
I'll decide what I get when the time comes. Right now, I'm not buying anything right now as my budget for the month is out
Maybe if I sell some crap... that'd be better...
I appreciate everybody's input on this.sigpic
I used both, on my lt1 car it was fine with a non adj...if i remember correctly i bought an adj for the ls1 but really didnt need it either2011 Ford Raptor SuperCrew
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
So I'm ordering UMI LCAs and PHB. I'm going with the non adjustable LCAs and on car adjustable PHB.. Good choice?sigpic
Why not do founders? Nothing against UMI, Ive had both brands but you save some money on the founders stuff2011 Ford Raptor SuperCrew
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
Founders is 219 for on car adjustable and rod ends... I'm going with that I think. Might as well get the adjustable in case I need it down the road, i won't have to spend more..
Yeah.. i think I'm going with this..sigpic
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
Err.. rod ends are not good for DD.. Going with poly bushings looks like..
Figured out what I'm going with..Going with the 3 piece poly LCA
http://www.foundersperformance.com/1...ceted_search=0
and just an adj poly poly PHB
Yay for money spending!sigpic
If youre worried about nvh at all use stock rubber bushings. I have founders adjustable rod end LCAs and i havent noticed any "noise" or negative effects from them.-Joel
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
good shit.
Drove the car this morning on 59.. Went from crooks to squirrel. It was "stable" on the way there.. On the way back, well it was terrible. Couldn't even stay on 59. Took Adams exit. The rear was swinging side to side. So, when these come in, I'll be doing the headers too! Those will be after the suspension because I know the headers will be a pain
Good choice, I was wondering why you were going with rod ends but didn't say anything. I have that PHB on my car and couldn't be happier with it.sigpic
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
It was 1 am.. brain wasn't functioning.Originally posted by MeenZ28 View PostGood choice, I was wondering why you were going with rod ends but didn't say anything. I have that PHB on my car and couldn't be happier with it.
I think I'm going to put the front on ramps, and back on stands. That way I can do the suspension first, then throw in the headers.. I believe I'll be starting next week.. Hooray!sigpic
Were you doing long tubes? You are going to want it higher than a set of ramps. Id do the suspension, and then put the front up as far as you feel comfortable for the headersOriginally posted by DanDalessandro View PostIt was 1 am.. brain wasn't functioning.
I think I'm going to put the front on ramps, and back on stands. That way I can do the suspension first, then throw in the headers.. I believe I'll be starting next week.. Hooray!1998 Pontiac Firebird T/A, M6, LT Headers, ORY, Borlamouth, tubular LCA and Panhard bar, lowered 1.5". More to come
Post Whore
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Full time student
Yeah I'm doing long tubes. The ramps are pretty high but I'm not going to use them.. I'd have em on already. Don't feel comfortable doing anything like this home alone at my house.. Bad shit can happen.. [emoji53]sigpic
