That's not a bad idea right there. I might even be able to run the ground wires off that too. Doesn't have to be pretty anyway. It'll all be hidden when all is said and done.
After thinking about it a bit that might not be best... if I ever have to pull the shelf back out of the car the relays would probably be in the way. The shelf was a tight fit as it is. Had to really wiggle that thing around to get it to drop in right. I was hoping to mount the relays right to the shelf so in the future all I'd have to do was unplug them from the harness and out comes the shelf... unless there's enough room to mount them behind that spare tire bracket... I'll have to look at it at lunch time.
