Was able to swap out the angle fittings in the block for straight after all so i have all the fittings for the bags now. I took some little time today and assembled the brackets to the bags just to get that done. Finished up the wiring on the compressors too. Must have done it all right cause with the key to on the compressors came to life. Yay! Truly all the compressor sytem is done now. All thats left is install the bags and brackets and run the air lines to the valve block and its done.
Had a thought today though. For such a high dollar system you'd think they could throw in one more gauge to show the psi in the tank. Im sure i could get one latter on down the road (probably put it in that third spot in the gauge panel) but come on Ridetech.
