"Shadowfax" - Jeremy's 15th Anv. Trans Am
Can't watch the video here at work, but looking forward to watching it when I get home. Glad to see you making some progress on it Jeremy!
so currently next on the agenda is as follows:
-finish engine harness (removing unneeded wiring, plugs, relays, etc. replace bad plugs, relays, and fuses)
-dial in qjet as best as possible
-clean engine bay (everything is dirty, old leaves and gunk, reservoirs are gross, etc)
-clean engine itself (valve covers, intake, etc)
-replace wiper motor
-finish tune up (plugs, wires, etc)
at this point my engine bay should be to the point where I can drive the car and not be totally disgusted by whats under the hood haha! after that I can start working on the interior!
Leave a comment:
I have a box of 3rd gen wiring connections when I stripped mine apart. If need some let me know and I can check to see if I have it
Leave a comment:
I successfully ripped out all the wiring on the passenger side of the car.. Which is the computer wiring.. Started to go through the driver side engine harness.. And boy is it gross.. Most if the plugs are broken and super corroded.. And then a bunch of random spliced and loose wires.. Gotta print out my diagrams and really look at what's going on
Leave a comment:
So just a small update.. But I currently have my carb taken apart and is soaking with some cleaner
Leave a comment:
i tore mine out and after crying to darren that it was confusing as hell i just started depinning it after labeling went very smoothly
Leave a comment:
oh yea.. I have most of the passenger side harness unhooked (the computer harness).. but there is still a lot of crossover that I have to figure out what does what.
Leave a comment:
Leave a comment:
