Nate's 1998 Z28 Project
  • How do I do a leak down test?
    Whats the possibility of the coolant temp sensor being the issue? Found a couple of threads that have pointed to that.
    • A leakdown test puts compressed air in the cylinder (at TDC) and determines cylinder leakage whether it be past the rings, through the valves, or through the head and block mating surface. You need the tester to do it. A coolant temp sensor problem "should" set a DTC as the PCM should be able to use the IAT to anticipate what the ECT should be, at start up at least. If you unplug the temp sensor (open) you should get about a -40 degree reading. Jumpering the connector should give you a very high temp reading. That can confirm the wiring integrity.
      2015 Silverado
      • You can also test the sensor as it is a thermistor so the resistance changes with temperature. So you can ohm it out while heating it up and the resistance should go up or down depending on whether or not its a positive or negative coefficient thermistor
        2015 Silverado
        • bought a new one.
          I got a two wire style, reading online my car should have a three wire - one wire going directly to gauge other two going to pcm.
          Bla 98's being different. lol
          • Replaced coolant temp sensor..no dice.
            What else am I missing?
              A BBC w/ a 1471 blower
              2015 Silverado
              • You've swapped coils but have you swapped injectors?
                2000 Formula
                fixed slow junk
                • Tested all injectors, swapped all injectors
                  Tested injector wiring with noid tester
                  New Plugs
                  New Wires
                  New O2 sensors
                  New Coolant Temp Sensor
                  New IAC
                  New TPS
                  New PCV system
                  HP Tuners confirms no vac leaks
                  HP Tuners confirms bank 2 running fine
                  Confirmed push rods are not bent
                  Confirmed springs are not broken
                  Can see rockers working correctly - assuming lifters are fine
                  Basically its bank 1 related, #7 primary is at 90 ish degrees while others are at 140 via infrared heat gun. It's not a open/closed loop thing. It's all the time.
                  What am I missing?
                  ________________
                  • Do you still have that messed up intake on?
                    • Originally posted by FASHOOTER View Post
                      No he replaced that.
                      Edit, any way you can trace some of your cylinder 7 wires back to your pcm? Maybe just those wires have corrosion or a loose wire somewhere?
                      2002 Z28 Camaro A4
                      1993 Z28 Camaro M6- SOLD
                      1999 Z28 Camaro M6- SOLD
                      2008 Ford Fusion SE - DD
                        Tested the plug with a noid tester, it blinks. swapped injectors again tonight..no improvement. The Cyl isn't getting fuel. When I had the intake off its dryer than the others.
                        Bad PCM?
                        • Pretty sure it's getting fuel. If you still have the noid light, put it on #7 with the key on the run position and move the harness around. If it flashes then you have a wire shorting to ground.
                          I'd like to do a leak down test before you pull the head. Compression tester can be made to work as one, just need to pull a schrader valve.
                          Did you compare #7 compression to any other cylinders? IIRC, it was 165...to me that's not far off what it should be with a cam.
                          • Potential solution. Injector plug. Noid test shows it as good, its clearly missing a piece. Now to find one...
                            • It's possible! I need to order a set of EV1 style connectors for a harness I'm doing which should come with 8 extra pins, that way you wouldn't have to cut into the harness. The pins use a special U barrel crimper
                              • It runs!!
