Nocooler's 00 Firebird
  • MMM on Sunday???
    2015 Silverado
    • Originally posted by Boost Addict View Post
      MMM on Sunday???
      If I was your age - yes!
      Need to finish the install - install the trunnions, and then break in the clutch. Then I can consider the track.
      2000 Formula
      fixed slow junk
      • Made some progess - no more green clutches for me.
        2000 Formula
        fixed slow junk
          Bigger - Trans is ready to go in. To friggin hot to deal with it right now. Should have setup the air conditioner in the garage
          2000 Formula
          fixed slow junk
          • Damn you gotta be sweating your balls off lol... lookin good so far!
            • Couldn't remember if I double checked the torque on the pressure plate bolts - so I started off this morning by removing the bellhousing.
              Cracked the 3rd bolt loose and caught my right thumb on the exhaust shield.
              4 stitches later.........It'll be a couple days before I make any more progress.
              2000 Formula
              fixed slow junk
              • Ouch! That's what you get for having exhaust shields! If you had a turbo you wouldn't need them near the bellhousing
                • Back to where I started yesterday - torque verified on pressure plate and bellhousing reinstalled.
                  I might do some little stuff on the car this afternoon - but between my thumb and the tetanus shot my right arm is pretty gimpy today.
                  Maybe this weekend I'll get the trans in.
                  2000 Formula
                  fixed slow junk
                  • another small update - passenger side rockers are done and reinstalled.
                    2000 Formula
                    fixed slow junk
                    • Can't wait to see you ripping the gears again..
                      • Rockers are done and back on the car:
                        2000 Formula
                        fixed slow junk
                        • Think you'll be good to go mid to late August for stanton jeremy?
                          • Originally posted by dawdaw View Post
                            Like to have it together this next week - and go from there.
                            Without any other issues I should be good.
                            2000 Formula
                            fixed slow junk
                            • Trans is in. Had to take the exhaust off - not enough muscle to install it solo with the exhaust on.
                              2000 Formula
                              fixed slow junk
                              • Made some progress today.
                                Exhaust is on, driveshaft in, clutch bled, trans filled with 50wt, tune flashed back to m6......
                                Car starts but some how I wired the clutch switch backwards, so I'll fix that tomorrow and put the interior back together.
                                Still to do later after everything checks out:
                                Replace front brakes
                                rewire all the extras to clean everything up, wb02, n20, line lock, etc.
                                Edit: clutch pedal is stupid light.....
                                2000 Formula
                                fixed slow junk
