Nocooler's 00 Firebird
  • So what is everyone using for front rotors and pads?
    My brakemotive stuff is done. Maybe 1500 miles and the rotors are warped and cracked from hole to hole in places.
    Need a pad that has minimal dust and will bring this heavy ***** down from 130+ in a hurry. No funds for drag brakes right now
    2000 Formula
    fixed slow junk
    • Look up ebc pads. Rock auto has raybestos drilled rotors, haven't used them but I might give them a try
      Sent from my SAMSUNG-SGH-I537 using Tapatalk
      2015 Silverado
      • My hawk and eradispeeds work great
        • Little out of my budget Larry.
          2000 Formula
          fixed slow junk
          • So is this bad boy staying 6 speed or auto? Hope to see you at Stanton again this year, I'll finally have my pile together lol.. another month and it'll be ready to go
            • Kyle - I'm planning on calling liberty next week if I get a chance. Idea is faceplate & mcloed rxt/billet flywheel. Monster want's me to run the stage 2 billet twin or the new LT1 style twin.
              I'm sure liberty will be a few weeks behind - and I'm not in a hurry at this point.
              All subject to the "Larry clause"
              2000 Formula
              fixed slow junk
              • Weeks might be an understatement . Uou could use mine but it needs an input or pocket bearing
                • Mine needs an input bearing at minimum. I'll call them and see.
                  2000 Formula
                  fixed slow junk
                  • Made a trip to libertys today
                    ecoboost averaged 20 mpg
                    2000 Formula
                    fixed slow junk
                    • Stuff done so far:
                      4L80 removed/sold and most parts gone
                      Swapped back over to the M6 pedals - what a *****.
                      Changed back to the t56 yoke
                      Installed tick master
                      Stuff ordered
                      McLeod RXT/Billet Flywheel
                      GM slave and pilot
                      rotors and hawk hps pad for the front - need to inspect the rears
                      Hurst pistol grip shifter with button - no more hand sliding off the ball
                      1-7/8" Speed Eng headers too cheap to pass up.
                      Things to do:
                      Center bellhousing
                      Install Clutch/Trans/drive shaft - bleed hydraulics
                      Rewire Nitrous and the rest of the accessories - after owning the car for 7 years and adding stuff it's a mess. Have leash's n2o board that should clean it up significantly.
                      Install new headers - when the show up. Debating on wrapping them
                      Build new y-pipe with flowmaster merge - mid-pipe has the aluminizing burnt off it after the merge, so I need more flow.
                      Things I'm considering.
                      Diet for the car
                      New front shocks - QA1 Gen F's on the car bounce when loose and don't transfer when tight
                      Trunion kit for the rockers
                      4.30 gears - get it out of the hole better -but have enough rpm to make it through the traps
                      Cam - flycut and mill the heads
                      What I really want to do:
                      Say **** it, sell top half of engine, n2o and call Jonny and boost this *****.
                      So if someone wants a proven heads/cam/intake setup and a nice n2o kit let me know
                      2000 Formula
                      fixed slow junk
                      • Awesome Jeremy! Can't wait to see this thing at Mid Michigan this year
                        I've got about 150 miles on the RXT and so far I am very impressed....I can't wait to lay into it. The thing is easier to drive than my LS7 clutch and I'm still in the break-in period. It seems I need to touch up my tune at idle now because it has quite a bit less MOI than the LS7 but other than that it's been great.
                        What does your car weigh now?
                        • Well sell me the n20 board if you do. You're gonna spray 4.30s? Where do ya plan on spinning it to and a 28" tire I'm assuming?
                          • Originally posted by 1999Black_Z28 View Post
                            Good news - I'm still waiting on mine - shipped yesterday. Still need the trans back.
                            Never had it on the scales Dave.
                            2000 Formula
                            fixed slow junk
                            • Originally posted by dawdaw View Post
                              I'll be keeping the nitrous - turbo is a pipe dream!
                              If I go to 4.30's yes i'll be spraying it. 6800ish with 28" tires. I'll see how it runs on the 4.11's with a clutch that doesn't slip.
                              2000 Formula
                              fixed slow junk
                              • All the parts are here except the transmission.
                                Liberty's haven't even looked at it yet
                                Need to get some motivation to go out and indicate the bellhousing - but it's kinda crappy out today.
                                2000 Formula
                                fixed slow junk
