Nocooler's 00 Firebird
  • i can say with almost certainty he would say tr6's.
    I usually run 110 or c16 in my cell. and when i first did it i had ms109 in the main tank also. Later i just used 93 and 110.
    Im gonna start with like a 75 shot with this thing. Not sure of the tuning window. Setup isnt the norm lol
    • I think that's what's in there now, but I need a non projected plug though right?
      Still need to get that dang fuel pressure gauge from you...
      Sent using Tapatalk 2 on Android.
      • Converter showed up today.
        2000 Formula
        fixed slow junk
        • Originally posted by Nocooler View Post
          Just in time for this cool fall air Make sure to take another degree out of it from the summer tune up
          • Just confirmed with PTC - 21 blade stator and straight fin angle.
            Should give me 400ish more stall and tight it up on the back end 300-400rpm and get rid of the slip
            2000 Formula
            fixed slow junk
            • Cant wait! 4l80e will be my next trans for sure.
              • There was just an rpm level 6 4l60 with a brake on Craigslist from a certain mustang. Was gonna get it for my truck lol
                • Spencer - just be prepared to cut.
                  Braces on both sides of the tunnel need cut to clear and it's still tight at the main connector plug.
                  I'd go 60 - but they cost so damn much to build.
                  4l80 is a strong piece for sure.
                  2000 Formula
                  fixed slow junk
                    your truck must be badass.
                    • lol no. stock daily driver. unless jon sells that supercharger. just wanted a trans that shifts. dealer put a brand new one in about a year ago and still feels odd
                        Lots of TM?
                        2015 Silverado
                        • idk i made sure it was a factory tune cause the dealer wouldnt. later i found a bulletin for the issue but the dealer wouldnt do it cause it was out of warranty then. detroit gearbox said he could do it with 1-2 piston mods. Tsb says 1-2 accum valve which requires valve body to be pulled
                          • Trans is in - just need to install the starter and drive shaft and I'll be ready to put some fluid in it and test
                            2000 Formula
                            fixed slow junk
                              Hope it works better then that FTI I had.....They had it twice and couldn't get it right. Replaced it with a YANK....never again FTI wasted a lot of time and money with them with very poor results
                              • Jim - sorry about you luck with FTI - what was it doing?
                                Car survived the 1 mile test drive......neighbors must have been impressed: exhaust uncorked and on slicks
                                2000 Formula
                                fixed slow junk
