TRY MEH'S 2000 ws6 build
  • #91
    was the wideband hooked up to the exhaust? why would it be so damn lean, doesn't sound right at all. Numbers look petty decent though, did Phil say anything else about the car when it was all done?
    • #92
      I thought 15 AFR sounded bad - if it was really that lean it would have inflated the numbers a bit
      • #93
        Post the graph. Its likely the lean spike when he either taps the limiter or lets out at the end of the pass. I'd bet its in the mid 12's the entire pull.
        • #94
          I know Phil wouldn't leave it that way, same reason I'm asking if it was like that for the pull it wouldn't make it home lol.
          • #95
            after reading the graph looks like it about 12ish through the pull but right off the initial hit it is above 15
            i tried posting a pic but cant do it on my cell
            2000 WS.6 Build <--- click to see
            1994 cummins turbo diesel 1million+ miles!! (rip dad)*my fathers old truck hell of a mechanic!
            • #96
              • #97
                Mid 12's like I thought. Shits mint. That power curve looks excellent. Car should run good.
                • #98
                  no doubt mine went 123mph with that much power through a slushbox.
                  • #99
                    Cant wait to run u lol I like getting my ass kicked any plans for 2day I think im going to replace my fuel pump 2day
                    • Congrats on the numbers! Hard work does pay off.
                      • so whats this car doing this summer ?
                        • Originally posted by Gregs_gsxr View Post
                          had all these parts sitting around for a bit just been busy
                          working on putting in the 12 bolt in (had issues with wheel studs i custom made some 5/8 wheel studs should work good just hunting down some closed lug nuts)
                          kyb adjustable shocks
                          umi torque arm
                          umi LCA's
                          umi cross member safety loop
                          umi panhard bar
                          umi 3point SFC's
                          NT05R Drag Radials 315-35-17
                          hopefully a paint job sometime soon wind storm scratched my car up pretty good i buffed most out but some were to deep =/
                          • How did you custom make the studs?
                            • Originally posted by BP_Z28 View Post
                              shoulda took pic's but hardend threaded rod *grade 8 i found and a lathe "it was actually some semi truck part that had the length of thread i needed i cut in half" works great
                              i had to open up my wheels 1mm to fit tough
                              havent been so active on the forum been insanely busy with work and things around the house.
                              • Wow great numbers man! Thats gonna be a fun ride.
