I don't know if you have a wheel set for this or not, but if not, I do! My buddy sold me his drag wheel set from his t-type last year, but they stick out too far on my 4th gen. They are centerline wheels with M/T ET streets, non radials. They fit perfect on regals and what not. Skinny's in the front and fatty's in the back. I was going to ask 350.00 this spring. If you're interested, let me know. Didn't read the whole thread to see if you had a set already so sorry if this is a pointless post lol. Lovin the build though!
87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
96 Z28 Camaro M6
2008 Silverado quad cab LTZ
Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
You have my intrest.Originally posted by Sic96 View PostI don't know if you have a wheel set for this or not, but if not, I do! My buddy sold me his drag wheel set from his t-type last year, but they stick out too far on my 4th gen. They are centerline wheels with M/T ET streets, non radials. They fit perfect on regals and what not. Skinny's in the front and fatty's in the back. I was going to ask 350.00 this spring. If you're interested, let me know. Didn't read the whole thread to see if you had a set already so sorry if this is a pointless post lol. Lovin the build though!
thank you. tell trevor to get busy. lolOriginally posted by Gregs_gsxr View PostTrevor is still stalking this build....
going to try and get in contact with Dr. phill would like him to tune this car im only going to run it out at 8 to 10 psi for now. when I get the second fuel pump installed and the rear axle I will push it a little harder. hopefully he will tune it it not a corvette or a f-body. and it is older. but we will see. I just want it tuned right so it will last a little while till I get over this sickness and build a motor from the ground up.
that was trevor posting lol. I keep telling him to stop dreaming and thinking so big and get it going.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Lol sneaky. tell him to get a screen name. And get that darn thing going lol.Originally posted by Gregs_gsxr View Postthat was trevor posting lol. I keep telling him to stop dreaming and thinking so big and get it going.
Originally posted by Gregs_gsxr View Postthe ls2 or ls3 cams wont work in the 5.3's
Sure they do. Just need to get the right cam gear and front cover with the CPS on it. You do want want a 3bolt cam, IIRC, ls2 cams from 05-07 are 3 bolt. LS3 is single bolt and there is no 2x cam gear with a single bolt setup.
Sent from my DROID BIONIC using Tapatalk 2
Originally posted by beertestr View PostSure they do. Just need to get the right cam gear and front cover with the CPS on it. You do want want a 3bolt cam, IIRC, ls2 cams from 05-07 are 3 bolt. LS3 is single bolt and there is no 2x cam gear with a single bolt setup.
well I guess I should have said its not a direct swap'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
you know I got your truck and trailer, trailer is at the steel shop, get at me with a time frame...I just dont have my straps cause AJ still has them for like a yr'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
u can borrow the yukon if i ever get this stutter problem fixed.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
