87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
That's awesome!- Brian Meissen
Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
Yes and thankyou very much. When she is running and tuned you will be going for a ride sir.Originally posted by TORN View PostGlad to see my old 72 Monte Carlo 400 small block mounts are going to good use. Project is looking killer man.
Sent from my HTC6435LVW using Tapatalk 2
Looks great Ken! I've always heard bigger turbos have better street manners. Are you still in Lennon?sigpic
I'm in the same area. Yes big turbos generally have better street manners till they spool. Then your on ice.Originally posted by ryanwarby01 View PostLooks great Ken! I've always heard bigger turbos have better street manners. Are you still in Lennon?
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Don't do this! You will need to change everything. Put a pipe in the water outlet (one that is close to the ID of the tube) and pull it over to the passenger side. The outlet will rotate, it's a pressed in pieceOriginally posted by masterfab View Post****I'm looking for a good used f-body water pump. something not to expensive but working. If any one has one the let me know. The stock water pump hits the throttle body.
That won't work. I just tryed it. dirty dingo make a spacer for the f body water pump so it will work with the truck acc. All you need is the pump and the belt.Originally posted by hoogiesngrinderz View PostDon't do this! You will need to change everything. Put a pipe in the water outlet (one that is close to the ID of the tube) and pull it over to the passenger side. The outlet will rotate, it's a pressed in piece
Sent from my HTC6435LVW using Tapatalk 2Last edited by masterfab; March 11th, 2013, 10:10 PM.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
True, forgot about the spacers. I was able to get both 5.3L pumps to work with the LS1 intake though. Two foot pipe and some heat from a propane torch and it rotated just fine.
Problem is I have a Lokar universal throttle cable and the end that attaches to the tb hits the spout and won't let it return to idle.Originally posted by hoogiesngrinderz View PostTrue, forgot about the spacers. I was able to get both 5.3L pumps to work with the LS1 intake though. Two foot pipe and some heat from a propane torch and it rotated just fine.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
ahh.
Smack the pipe with a hammer
I'll probably run into this then, planning to run Lokar in the '60 Impala
You know I was thinking a throttle body spacer might work to. I has a video going up in about 30 minutes showing the problem.Originally posted by hoogiesngrinderz View Postahh.
