87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
  • #76
    I've been known to do a few good photoshops Find me a good angle and I'll see what I can do, white cars work best
    • #77
      Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
      Will primer due. I may be able to find something on the internet if not.
      Sent from my HTC6435LVW using Tapatalk 2
      • #78
        Should work, as long as the car is solid primer. Any color change/tone will ruin a good outcome
        • #79
          Ok let me see what I can come up with.
          • #80
            sounds good, gives me a reason to use the pen tablet "I just had to have"
            • #81
              Sounds like a good reason to me, lol.
              • #82
                Waiting on Santa again.
                • #83
                  gnx flares, ss scoop, some crosslaces, and the two tone and vuala!
                  00 Tahoe Z71........Stock
                  • #84
                    More parts.
                    Lokar 4l80e dipstick tube/ ls1 throttle cable and bracket.
                    B&M stealth pro ratchet.
                    • #85
                      what else are you waiting on ?
                      • #86
                        Odds and ends/ hot side tubing/ wiring harness/ pcm and gary to give me a spot in his garage.
                        • #87
                          Why can't you work in your garage? You just got a badass lift didn't you?
                          • #88
                            I thaught you knew. I had a lot of bad stuff happen all at ounce. cancer being the biggest. and lost my house. I had to make a choice house or family and I let the house go. there's way more to it than that but that's the short version. I'm sorry if I would have known you didn't know I would have made it a point to tell yah bud.
                            • #89
                              Garage or not I gotta do something. So this boss gave me rare permission.
                              • #90
                                I know there a lot of question of which shifter to use with the 4l80E transmission. I can tell you that the stealth pro ratchet works perfect with the trans. And retains the factory prndl switch. You have to use a additional parts kit from B&M part # 75498.
                                I know some also know this works, but the are a lot that dont.
                                Future video of operation. (I'm just trying to take the guess work out for some people)
                                video sux
