would it matter that i used the IAC that cam with the motor (truck throttle body) in my LS1 TB?
'94 firebird formula.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Shouldn't, mine didn't care.
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Do you have a copy of the tune or a log file with it running?
i don't, my buddy is doing the tuning. i'll see if he can send me a log next time he tries messing with it. he found a stock tune for a ws6 and just tweaked it for my car.Last edited by formula218; June 10th, 2015, 09:37 AM.sigpic
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
What MAF are you using? I can't remember if you used a truck harness or LS1
stock LS1 maf and LS harness.sigpic
I think we've finally figured out all of the issues with the car! I already ripped the exhaust off driving it one day to tomorrow i'm going to put it back on and BFH the pass. side back floor to try and tuck the muffler up a little higher.
the idle is fixed, and the speedo works!sigpic
now my headlights quit popping up, it's just one thing after another with this car lately.
hopefully it's just a fuse. the lights come on but don't raise up.sigpic
i can still manually crank them up and it doesn't make any noise like it's trying to move them but can't.sigpic
figured out my headlight problem, there was a connector behind the drivers side light that was undone (that part that hooks to the stock air box) fixed that, got my SLP Flowpac/SSRA intake installed. i had a couple valve cover grommets that were leaking down onto the headers so i pulled them last night and replaced all the grommets, just waiting on a new set of OEM valve cover gaskets that should be here tomorrow to seal it all back up. the inside of my VCs where absolutely covered in oil gunk so i Simple Green and wire brushed the hell out of them. once i get it back together i need to run something through this motor to clean it up some, it was not pretty in there.Last edited by formula218; August 5th, 2015, 11:47 AM.sigpic
Haven't posted in the build thread for a while. swap is still running strong! i bought a Nitrous outlet TB plate for it a couple weeks ago, should be ordering a few other goodies soon so that I can spray it next spring. This Sunday i'm planning to take it to the track and get some baseline times before I start modding it.sigpic
