I don't see why you wouldn't be fine on the street, our car will see its fair share of street duty, we even plan to drive it to the track and back after we shake the bugs out. Having a cage won't have anything to do with the power level unless you plan on taking it to the track all the time or entering in events with it. Just depends on how safe you feel in the car at that power level. That being said I can forsee next winters project already as I think safety will be a concern with the direction we're headed and I will likely want the protection of a proper roll bar.
Project: The Timebomb
Sounds like things are coming together. I have been watching the progress and have been learning a lot from you both Mike and Jeff. One day I'd like to have a turboed LSx keep up the good work!2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
couple of much overdue pics, the last of which just arrive about an hour ago.
New catch can
Rest of things I needed for the front coilovers.
Decided after seeing Kolin's car that rustoleum was a good idea (I also used it on my rear end in the past and it still looks great), plus its about half the price for these 2 quarts as it was for one of the chassis saver or POR-15
Re: Project: The Timebomb
Gonna keep an eye on how you do the rustoleum. I need to do my Camaro. While under it, noticed some surface rust in some spots.
I have used it before and no worries I have a painting hat and long sleeve shirts I can dispose of, just gotta get some cleaning done so I can start. How did you guys clean Kolin's before paint?Doing less with more
I've said it once, I'll say it again...TSP It's perfect for pre-paint....matter of fact that's it's main purpose. I use it all the time because it cleans so well. Home Depot or lowes carries it.Originally posted by DETROITMUSCLE View PostI have used it before and no worries I have a painting hat and long sleeve shirts I can dispose of, just gotta get some cleaning done so I can start. How did you guys clean Kolin's before paint?sigpicTurbo Charged LS1/T56
I can run out and grab some, looks like powder that I assume you mix with water?
b17000a6-7a98-4783-bc65-686596a981c7_300.jpgDoing less with more
Originally posted by DETROITMUSCLE View PostI can run out and grab some, looks like powder that I assume you mix with water?
[ATTACH=CONFIG]48522[/ATTACH]
You can get it in liquid concentrate. Alittle goes a long way. I just did the whole underside of my car with a few ounces mixed with water.sigpicTurbo Charged LS1/T56
I picked some up, going to mix a little in a spray bottle after lunch and get started.Doing less with more
