ls1 blazer
    Originally posted by t_ank View Post
    well i have the axle shalf out the axle theres a pic of it. yea your 2 hours and ten minutes away =/
    me and a guy were talking about it tonight yes i believe its cast iron and he said the stick was like 8 bucks but i dont know for sure im going to look into it more tomorrow and yes you can weaken it if not done right just have to do a little by little. ill know more tomorrow but if idont or cant get it done ill hold off just like to do it before i put it in. the neighbor said he do it for 40 bucks? i know thats good compared to the friend of mine that wants a 100 lol i know welding guys get alot but come on now if i had the stuff to do it i would but i guess we might have it tomorrow so we will see
    I did some more reading, looks like they aren't cast iron but rather cast steel. I'd still preheat but spot weld around then run 1" beads (or less) 180* apart to help avoid warp. I'd keep a torch on it between welds and then wrap it in insulation when finished to keep it from cooling down too quick
      i read almost the same thing use nickel rod is the best to use. but thanks for the search also. just have to wait and see tomorrow.
      05 cts
      01 silverado 2500
      96 s10 blazerrr
      84 k5 blazer
        I'll have to check with my metallurgy guru friend (certified pipe welder) but I think cast steel can be ARC, MIG, and TIG welded w/o any special filler. I'd be mostly worried about heat dissipation causing brittle welds.
          Nice truck....love the sunburst orange
            No way would I drill the axle flange myself.
            Without the proper fixture you'll never get the bolt circle round or concentric.
            If you have lug centric rims - that thing will shake you to death all the way down the road.
            Take them to a machine shop that can handle them - it'll save you a ton of grief.
            2000 Formula
            fixed slow junk
              there probably going to go to a machine shop but they a correcting marked and should be fine
              05 cts
              01 silverado 2500
              96 s10 blazerrr
              84 k5 blazer
                thank u
                05 cts
                01 silverado 2500
                96 s10 blazerrr
                84 k5 blazer
                  well got the axle painted finally decide not to weld it at this time.
                  worked on the exhaust today had to tighten up some bolt noticed a little exhaust leak so me and my son did some work well he watch but yea get it lol took a few pics of that.
                  also thought i share my buddy airbrushing work on ls7 fail rail covers they are hydro dip and air brushed
                  05 cts
                  01 silverado 2500
                  96 s10 blazerrr
                  84 k5 blazer
                    wax on wax off today
                    05 cts
                    01 silverado 2500
                    96 s10 blazerrr
                    84 k5 blazer
                      GARAGE SALE FIND $10 BUCKS
                      ALSO BRING MY AXLE HOME FROM PAINT TODAY!!
                      05 cts
                      01 silverado 2500
                      96 s10 blazerrr
                      84 k5 blazer
                        picked up some tt2s 17x9.5 17x11
                        also got the work truck wheels painted
                        05 cts
                        01 silverado 2500
                        96 s10 blazerrr
                        84 k5 blazer
                          yes or no im undecided
                          05 cts
                          01 silverado 2500
                          96 s10 blazerrr
                          84 k5 blazer
                            Put air in those tires!
                            I dont think you can go wrong with TT2's
                              lol i will just got them last night. have to pump them up im not gonna be able to run them all i have to get the axle in first for the rears cuz they are so wide
                              05 cts
                              01 silverado 2500
                              96 s10 blazerrr
                              84 k5 blazer
                                I thought 8.8 Exploder rears were 5" wider than 2wd S10/15 rears?
                                The offsets look different, are the 11" high offset and the 9.5" low?? If so, it will actually work...but I think it would look a little funny.
                                On a side note, did you get the wheels from a guy named Brad? I think he ran that setup on his Iroc when he switched to a 4th gen rear
