ls1 blazer
  • #91
    Imlay city
    • #92
      Nice.
      Well today i purshased rotor n pads for the 8.8 and drilled the rotors for chevy lug pattern
      05 cts
      01 silverado 2500
      96 s10 blazerrr
      84 k5 blazer
      • #93
        Dropped the axles off to get milled down last night so i can run my vette wheels.
        Just need to add my fluid n put the brake lines in cant wait
        05 cts
        01 silverado 2500
        96 s10 blazerrr
        84 k5 blazer
        • #94
          Well finally got the axle in and wheels on. More pics tmr. I raised it up a inch in the back hard to tell in the grass probably lower it all little
          05 cts
          01 silverado 2500
          96 s10 blazerrr
          84 k5 blazer
          • #95
            That looks great !! nice work !
            Go BIG or go HOME!
            • #96
              Thank you sir. It wasnt a direct axle swap so it took patience for sure but i got it. Going from the 3.08 open 10 bolt to the 3.73 8.8 lsd is def nice : )
              05 cts
              01 silverado 2500
              96 s10 blazerrr
              84 k5 blazer
              • #97
                noticed a not so beautiful noise from the blazer today
                after a oil change and cutting my tail pipe off and putting a turn down on. i noticed a little bit of hestation maybe sluggish and a long time to decel. not saying any of this caused my new noise. but i dont know its always something last night my cts wouldnt start and now this.
                heres a video
                http://static.photobucket.com/player...psd902f234.mp4
                What you guys think....
                05 cts
                01 silverado 2500
                96 s10 blazerrr
                84 k5 blazer
                • #98
                  Heres a nice rolling shot my buddy took a couple weeks ago
                  05 cts
                  01 silverado 2500
                  96 s10 blazerrr
                  84 k5 blazer
                  • #99
                    check the rockers
                    • tomorrow im pulling the value covers so hope to find something out.
                      check the rockers
                      05 cts
                      01 silverado 2500
                      96 s10 blazerrr
                      84 k5 blazer
                      • Looks good. I've always wanted that truck.
                        Fwiw, when I had my 2.4x gears in my 78 imp, it wouldn't go beyond 5500 rpms wide open. Now with the 3.73 gears, it screams up to 7000. Gears definitely make a difference
                        Sent from my DROID RAZR using Tapatalk 2
                        96 BBB Impala SS-Fixed, Broke, Fixed again
                        95 DCM Caprice Wagon-STRKDIT
                        93 Caprice Classic- Whore
                        • Pulled the value covers nothing out of the norm
                          05 cts
                          01 silverado 2500
                          96 s10 blazerrr
                          84 k5 blazer
                          • Anyone have any ls7 lifters? Or new headgaskets head bolts etc
                            05 cts
                            01 silverado 2500
                            96 s10 blazerrr
                            84 k5 blazer
                            • The last few days you have seen i discovered a noise in the motor. Well today i finished pulling the heads off and getting the lifters out and this is what i found.
                              3 pretty ate up lifters and a few others with scored, flat spots etc
                              Lobe on cam ate up hard to see pic tmr after pulled
                              Tore down motor
                              So now i dont know what to do... let it sit til i can do what i want n build it or out it back to stock =\ cant believe how much it cost to fix lifters would be now throw a cam into the mix and nrw timing chain etc blah blah blah she might be parked til next season
                              05 cts
                              01 silverado 2500
                              96 s10 blazerrr
                              84 k5 blazer
