Not much set in stone right now, hoping to be around 350-400hp at the wheels. I'm thinking a stock rebuild on the bottom end, .030" overbore, mild/moderate cam (something similar to the LT4 HotCam but a little more aggressive), P/P heads, ported intake, upgrade fuel injectors and fuel pump. Replace accessories and wear items (timing set, optispark, water pump, PS pump, alt, A/C comp, etc.). Blueprinted/balanced bottom end, all new bearings, check clearances, deck and head machining to ensure absolutely flat, no flaws, etc., replace freeze plugs, new oil pan, pump, pickup, etc.
Basically replace everything, make it a brand new engine with a bit more power than stock. Also working a deal to replace the high-mileage transmission with something a little more. . . "deliberate". . . Should have trans this week, engine parts ordered this week (some of them, anyways), and the engine/trans that are in the car will be removed this week.
Overall, the goal is for 350-400hp of streetable, reliable power that won't break the bank. Not in a financial situation right now to buy a crate motor or anything, but dumping money a little at a time is a little easier to handle. The engine will be mounted to a stand and built over the winter, and I will likely have several friends helping me so I don't screw this up. Trans is good to go, but I will need to upgrade the rear end at some point along the line to handle the additional stress, and I'll want gears to make things more fun.
While the engine is out, I'll do some work on the engine bay to repair rust and clean things up. Car will be kept in a garage for the winter, engine/trans will be installed in the spring (assuming funds allow rebuild to be finished by then)
