wasnt able to grab any more pictures today as it got to dark before i finished up with some other things.. but everything is down and the dumpster will be picked up tomorrow.. then its on to moving the rest of the rocks... pictures tomorrow
looks like that thing still has some good bones. good luck with the build what are the plans for it so far? if you plan on running electrical/water and heat now would be the time to spend the extra and do it
it will have all of the above.. there is already electrical out there from the one we tore down, gas for thr furnace, and water will be out there as well.
Why not? With running water you're already there. I've seen guys on GarageJournal put the urinal in a corner and then just build a piece of plywood divider that sticks out to give you the privacy. Two mandatory items for a larger size garage: urinal and beer fridge. They really do go hand in hand (no pun intended).
Looks awesome so far, can't wait to see it done You guys are going to love having a barn of that size. Just make a second story loft, then you never have to move out
i'll either A) walk into the house.. its a 50 foot walk.. or B) walk around the corner and take a leak.. once u see the finished pictures of this you will also see on one side there will be no room for a urinal as there is to many machines (lathe, drill press, welders, Big bench, heater, woodstove, etc) there isnt going to be room for one.
