Project New Garage...
    OSUM!
    1998 Camaro SS Bullseye Turbo
      hell yea!
        wasnt able to grab any more pictures today as it got to dark before i finished up with some other things.. but everything is down and the dumpster will be picked up tomorrow.. then its on to moving the rest of the rocks... pictures tomorrow
          looks like that thing still has some good bones. good luck with the build what are the plans for it so far? if you plan on running electrical/water and heat now would be the time to spend the extra and do it
          00 Tahoe Z71........Stock
            it will have all of the above.. there is already electrical out there from the one we tore down, gas for thr furnace, and water will be out there as well.
              Sean - you have to add a urinal to the new garage. That'd be awesome.
                yeah thats not going to happen.. lol
                  You will love that garage. The barn I built at my old house was a 24'x74'. Nice to be able to get 2 hoists and 10 cars in it will all of my stuff.
                    Why not? With running water you're already there. I've seen guys on GarageJournal put the urinal in a corner and then just build a piece of plywood divider that sticks out to give you the privacy. Two mandatory items for a larger size garage: urinal and beer fridge. They really do go hand in hand (no pun intended).
                      Looks awesome so far, can't wait to see it done You guys are going to love having a barn of that size. Just make a second story loft, then you never have to move out
                        looks great so far the old one still looked like it was in great shape.
                          i'll either A) walk into the house.. its a 50 foot walk.. or B) walk around the corner and take a leak.. once u see the finished pictures of this you will also see on one side there will be no room for a urinal as there is to many machines (lathe, drill press, welders, Big bench, heater, woodstove, etc) there isnt going to be room for one.
                            If you guys are using an indoor woodstove for heat, I would suggest a ceiling fan above it as it makes the shop heat much faster/more evenly.
                            p.s. how are you guys insulating the roof?
                              Urinal's are over rated...I had one in my garage (was there when i bought the place) I never used it...finally took it off the wall and pitched it.
                                I've also seen people put a pipe in the wall that goes to an underground sump
