Black Beauty
  • $250 is on the cheaper end for a "high performance" clutch.
    • Black Beauty
      Yes the price is cheap but I've heard nothing but good reviews on them so I hope it's not crap..
      1997 Trans Am
      T56 swap. LS1 Cosmetics
      • I was thinking about a Competition Clutch but they are only rated to like 450ft lbs for a LT1.
        So I ended up getting a Spec 3 which is 76xft lbs. So I won't have to worry about changing it, when the engine build comes.
        Originally posted by Yoshi94
        • Black Beauty
          See my engine will never reach that so I should be set.
          1997 Trans Am
          • There are a lot of positive reviews on Competition Clutches. I used to run one and never had an issue. I thought it was great. You can't beat them for the money.
              what series? 2250 or the 2600?
              1997 Trans Am
              • Originally posted by QuickTop View Post
                2250
                  2250
                  i went for a more agressive one..
                  how long did you break yours in for?
                  1997 Trans Am
                    Honestly? Probably 10 miles. I wasn't too concerned with the break in.
                      and it lasted just fine? no chatter?
                      1997 Trans Am
                      • I only had it in my car for about a year before I made some changes, but it looked fine when I removed it and I beat on it frequently.
                        • awesome, thank you!
                          1997 Trans Am
                          • Black Beauty
                            Minor update that probably didn't need pictures. But I've got them anyway. The console I got had a minor crack. If I didn't have so much time on my hands I probably would've left it alone, but I got it JB welded from the back side. We're good to go.
                            And after
                            T56 swap update. The auto trans is out. Flywheel and pressure plate/disc assy. Are on the car. Ill try and get some pictures of that tomorrow. Spring looks like it's right around the corner, so hopefully by the time it's done I can start DDing the car again.
                            1997 Trans Am
                            • a few teaser pictures.
                              1997 Trans Am
                              • Hey come over tear my trans out. Got a clutch to put in, engine plate, bell housing.
                                Looking good though.
