Project White Out 2011
  • Originally posted by Gregs_gsxr View Post
    yessir, should be on the road in a 2 weeks, was shooting for the M&G but we'll see.
    QFTW
    Makin Torque.
    • key word...should, can't help if things come up thats out of my control
      • exhaust sounds great !
        • [MENTION=1023]OVRKILL[/MENTION] since he told me to worry about my car....
          exhaust is done, sounds wonderful, hood, bumpers on and checked for fitment, buttoned up and check for over heating problems, found out my cooling fan has a bad bearing, so that will get fixed. Looks like Im leaking a small bit of power steering fluid some where. Next after the 4th is final blocking, sealer, block seal again, spray color and clear in a booth, wet sand polish and install new weather stripping too.
          PS> the posi works great, brakes are F'n killer
          • Did Jeff do your exhaust?
              not this time, I just couldn't swing the $1100.00 with so much coming up lately
              edit: cars been finished and sold
              • Damn this cars gone? any pics of what it looked like when it was done?
                  • proof it was finished
                    00 Tahoe Z71........Stock
