No problem. Glad it went to someone who can use it instead of getting thrown out.
Project White Out 2011
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
rear end is back in its home under the camaro, just so I can move it around in and out of the garage. Picked up a few goodies as well, I couldnt have pasted up on. I also started D/A sanding down the car. Found one little quarter size bondo dent right at the passenger side spoiler piece. Other then that painting is gonna be easy and specially with no body work.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
That's great news Greg! So not going to have it media blasted anymore?Originally posted by Gregs_gsxr View Postrear end is back in its home under the camaro, just so I can move it around in and out of the garage. Picked up a few goodies as well, I couldnt have pasted up on. I also started D/A sanding down the car. Found one little quarter size bondo dent right at the passenger side spoiler piece. Other then that painting is gonna be easy and specially with no body work.2000 Trans Am l 1967 Firebird
Thanks Fred, the media blasting is not needed, I just need to take some strong de-greaser to the under carriage though. Since Im going to be spraying this in my garage, I cant wait for some actually constant warm weather'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
best way to remove old underbody coating ? should I just scrap it out, think aircraft paint stripper would work?'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Is this the thick tar-like stuff? If so you can try a heat gun or if that doesn't work make sure there's nothing flammable on the other side of the metal (ie remove your carpet, etc.) and heat it up with a mapp gas blowtorch and scrape away the majority of it and after it cools follow by hitting the area with some acetone if it's just a residue left, or use a wire brush to clean the remains if needed.
sure is the tar stuff, but its hard, not sticky by any means. I have a mapp torch so Im gonna try that, then a wire wheel. thanks Jim'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
No prob. Just as a warning, it's going to suck lol. That's the one thing that I universally hear guys ***** about when building a race car. I'd also have some wet rags handy to cool stuff down in an emergency. The tar will try to burn.
gregg you have the same coating i had on mine. i used a electric angle grinding wheel with a heavy wire wheel and it mad short work of it. then i sand blasted. or you can use acetone after you use the wire wheel.Originally posted by Gregs_gsxr View Postbest way to remove old underbody coating ? should I just scrap it out, think aircraft paint stripper would work?
I spent the better part of one winter taking all that coating off of mine...what a mess. Like the other guys said....torch, scrapers and wire brushes are the only way. Lacquor thinner will help with all the residue. I bought a tyvek suit (with hood) and a respirator. You want the hood on the suit to keep the tar out of your hair cause it's not cool if it gets in there...ask me how I know.
sigpicTurbo Charged LS1/T56
good callOriginally posted by birdie2000 View PostNo prob. Just as a warning, it's going to suck lol. That's the one thing that I universally hear guys ***** about when building a race car. I'd also have some wet rags handy to cool stuff down in an emergency. The tar will try to burn.
thanks thats probably what I'll be doingOriginally posted by sniperperformance View Postgregg you have the same coating i had on mine. i used a electric angle grinding wheel with a heavy wire wheel and it mad short work of it. then i sand blasted. or you can use acetone after you use the wire wheel.
how do you know ?Originally posted by WMCCjames View PostI spent the better part of one winter taking all that coating off of mine...what a mess. Like the other guys said....torch, scrapers and wire brushes are the only way. Lacquor thinner will help with all the residue. I bought a tyvek suit (with hood) and a respirator. You want the hood on the suit to keep the tar out of your hair cause it's not cool if it gets in there...ask me how I know.
with no work after tonight till next week. Im going to be working on the camaro pretty good, weather looks nice too. I'll be posting some pics too throught the week.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
greg here's those links.
http://www.competitionproducts.com/R...fo/RBG350-000/
http://www.competitionproducts.com/E...ductinfo/6190/
this is a cam-kit not to agressive but sounds great. (iv used these before there cheaper than a complete hot cam kit and have what your looking for)
http://www.summitracing.com/parts/CCA-K12-600-4/
These next 2 links are together a cheap cam and lifter kit.( there is no timing chain and gears set like the one above )
http://www.summitracing.com/parts/HR...s/?prefilter=0
http://www.summitracing.com/parts/HRS-98214/
Oil pump. ( the motor will be open good insurance)
http://www.summitracing.com/parts/MEL-M134/
Iv used alot of the brand above on budget motors with great luck and durability.
let me know what you think
thank you Ken, Im looking them over now I agree, with the oil pump so thats going on the must buy list along with the ring, bearing kit, whats your thoughts on gear driven timing chains, just for the different sound of course.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
